Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-13-2008, 08:24 PM   #1
Spitfire80
CF Senior Member
Spitfire80's Avatar
Default 1981 Vette. Body mounts. Location ?
Anyone....
Can anyone talk to me about body mounts.
Where are they and how many of them ?
Diagrams anywhere ?
Big job changing them ?
How do you know they are shot ?
Phil
Spitfire80 is offline   Reply With Quote
Old 04-13-2008, 08:34 PM   #2
A88FXRS
CF Senior Member
Send a message via AIM to A88FXRS
4 eachside. can go easy if bolts cooperate or can be a royal pain. can raise body and do one side at a time.
A88FXRS is offline   Reply With Quote
Old 04-13-2008, 08:42 PM   #3
Spitfire80
CF Senior Member
Spitfire80's Avatar
Default Where r they ?
Cool....
Where are they ?
What do I need to do to change them ?
Thanks again !
Phil
Old 04-14-2008, 01:28 AM   #4
Jack Bauer
CF Senior Member
Jack Bauer's Avatar
i don't remember the size of the bolts but it's nothing special. the front ones are forward of the birdcage. you have to access them from under and inside the wheelwell. the second set you get from inside the cockpit. remove the kickpanel down at the footwell. the third (if i remember right) is just forward of the rear wheels. i'm really fuzzy exactly but i think you have to get them from the outside. the last set is in the very back of the luggage compartment. pull up all the carpet from the rear forward and you'll see a well on either side that has the bolt. use penetrating oil a day or two before to help with the rust.
hope that helps.
Jack Bauer is offline   Reply With Quote
Old 04-14-2008, 06:57 AM   #5
redwingvette
CF Senior Member
redwingvette's Avatar
Send a message via AIM to redwingvette
Here is the layout of the birdcage
Click the image to open in full size.
__________________
Brian
73 coupe
Edelbrock Performer RPM Heads and intake
Holley carb
Crane Cam and roller rockers
BTO 200-4R trans, 3.55 gear
Leather seats, F-body seatbelts, Pioneer CD player
Body off repairs
Magnaflow Exhuast System
Dewitt rad and dual electric fans
Nostalgic Air Parts (AC system)
Borgeson Steering
NCM Lifetime Member
home page
redwingvette is offline   Reply With Quote
Old 04-14-2008, 07:42 AM   #6
SIXFOOTER
CF Senior Member
Support Corvetteforum!
SIXFOOTER's Avatar
There are 8, 4 each side.
If you have no rust issues they are not a real bad job, but its some work
Rattling body, doors not lining up, body lean on the frame, all those indicate compressed mounts. Yours is an 81 so they are compressed, count on it.
Replacing them I would go with Urethane, last time you will ever replace them. Its just there to isolate the body from some frame vibration, so anything other than solid mounts will work. I like the urethane because its more stabil than rubber.
The passenger side is pretty easy, loosen all 8, then use a floor jack with a piece of wood to lift the body a couple inches off the frame and replace the mounts. Clean and paint the metal under the mount cussions whilt its off of them. be sure and get the shims back in the same locations.
The drivers side takes a little more work, you will need to disconnect the rag joint for the steering and the brake lines going to the MC.
Tanke a look at the #2 mounts before doing anything else, see what they look like, this could be a bag of snakes.
SIXFOOTER is offline   Reply With Quote
Old 04-14-2008, 08:18 AM   #7
2Much Trouble
Junior Member
I believe there is one on the nose as well. If you are taking the complete body off (not just from the firewall back) It can be an ugly job
an air ratchet makes it much easier. When I replaced the mounts and the front clip(body from firewall forward) I couldn't find that bushing new, I used a front differential bushing instead. Good luck
2Much Trouble is offline   Reply With Quote
Old 04-14-2008, 09:46 AM   #8
Spitfire80
CF Senior Member
Spitfire80's Avatar
Default Thanks So Much Guys !!!!
Old 04-14-2008, 11:15 AM   #9
L82shark
CF Senior Member
St. Jude Donor '08
L82shark's Avatar
do a thread search in this forum for "body mounts" numerous tricks and tips and lots of pics......
L82shark is offline   Reply With Quote
Old 04-14-2008, 05:14 PM   #10
I'm Batman
CF Senior Member
St. Jude Donor '07
I'm Batman's Avatar
Send a message via AIM to I'm Batman Send a message via Yahoo to I'm Batman
Quote:
I did a writeup on my install which was not part of a body-off restoration.
I'm Batman is offline   Reply With Quote
Old 04-14-2008, 07:41 PM   #11
Spitfire80
CF Senior Member
Spitfire80's Avatar
Default SEARCH tool
Tried but the tool doesn't take more than one word .... right ?
Maybe using QUOTES will work ?
Sorry guys, new to this.
Will experiment further with the SEARCH tool
Old 04-15-2008, 06:15 PM   #12
I'm Batman
CF Senior Member
St. Jude Donor '07
I'm Batman's Avatar
Search will take as many words as you want. Read the "Search!" sticky for information on getting into the Archives.
Reload this Page 1981 Vette. Body mounts. Location ?
Tags
1973, 1981, 81, body, bushing, bushings, change, corvette, kit, locations, motor, mount, mounting, mounts, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
