Elementary Electric Choke Question
Old 04-14-2008, 05:56 PM
Five-spot
Five-spot's Avatar
Default Elementary Electric Choke Question
OK, This is one of those asking a stupid question is better than making a stupid mistake deals, so bear with me. With the engine off, should the choke shutter be in the open position or the closed position. I have an electric choke on a demon carb.
Old 04-14-2008, 06:07 PM
Binnie77
Binnie77's Avatar
The choke will be closed when the engine is cold and partly during warm up. If you check with a hot engine, the choke should be wide open. And there are no stupid questions!
Old 04-14-2008, 07:35 PM
BigBlockk
BigBlockk's Avatar
The choke will be wide open on a cold engine until you set it with the throttle, at which time it will snap closed. It will then open slowly as the engine warms. When the engine is at its operating temp the choke should be wide open.
BigBlockk
Later.....
Old 04-14-2008, 07:47 PM
Five-spot
Five-spot's Avatar
OK, Question #2: Should an electric choke be hooked up to a full-time
hot or a switched hot?
Old 04-14-2008, 09:05 PM
BigBlockk
BigBlockk's Avatar
You want the choke coil to be energized whenever the ignition switch is in the on position. I believe this is called "switched". If it is wired up "full time hot" the coil will always be hot. In other words you will not be able to apply the choke. This will make starting the car rather difficult, to say the least.
A good place to get 12 volts is the hot side of the windshield wiper motor.
BigBlockk
Later.....
Old 04-14-2008, 10:38 PM
Five-spot
Five-spot's Avatar
The choke is currently wired to theswitched side of the alternator. This did not strike me as a particularly good idea. Should this be moved to the above mentioned location or is the alt. hook-up a reasonablr alternative?
Old 04-14-2008, 10:44 PM
blckslvr79
blckslvr79's Avatar
seems like you'd want it fused to me???
Old 04-15-2008, 09:06 AM
BKarol
BKarol's Avatar
What I did was buy an oil pressure sender ($17) and tap in the block right under the dist. One line goes to the wiper motor for hot and the other prong is for the choke wire. In this way if you work on your engine with the key on (not running) there will be no current to the choke because there is no oil pressure.
Old 04-15-2008, 09:11 AM
Binnie77
Binnie77's Avatar
What an innovative idea!
Old 04-15-2008, 09:15 AM
Dantana
Dantana's Avatar
Very clever Karol. Very clever
To Elementary Electric Choke Question
Quick Reply: Elementary Electric Choke Question
