Fiberglass repair
Fiberglass repair
I just found a small crack in the panel near the bolt that the door closes and attaches to. Is there something I can get to put on this to prevent it from spreading/running? The crack is very small, right now, but needs to be attended to so any ideas would be appreciated.
Fiberglass repair
Found in the archives where it said that the 73 model needed to be epoxy based. Found the epoxy and resin in mixable tubes at AutoZone that you squeeze out for the correct mixture. Applied it to the crack, let it dry and then roughed it up a little once it dried. After that I touched it up with some matching paint and then buffed it out. So far I'm very pleased.
I think it's going to work because I applied it to some other fiberglass I had laying around for a test and after about 2 hours it was solid. No flex and it filled in the cracks.
I guess we'll see. Thanks for replying and staying in touch.
