Hooker side pipes exhuast leak too loud. What mufflers do you recommend?
Im running hooker side pipes with glass packs it has a nasty little tick where the pipe meets the collector it seems to leak. Always a black ring around it looks crummy and sounds ****ty . Here is a video
Now it don't sound too bad but it has a ratty tick as you can hear. I was told its because the mufflers are too restrictive but they are glass packs . Anyway im looking to fix the leak and maybe replace the mufflers with something less restrictive and nice sound though nothing louder these are hard on my ears
I have the reverse flow baffles and since a short period of time I have the same problem, but only on the drivers side. You can see the restriction of the baffles I have on the picture below by the way.
Since passenger side is fine and I didn't have any header leak before I took the pipe off when changing my heads I'd say it's not totally a pressure matter. Us taking of the pipe took quite some force and as a result of the wiggling left and right it became more oval than round I guess. We tightent the pipe bolt as much as we could and then hammered around the pipe to shape it up a little. This helped, but not too much.
Long story short:
Long story short:
Cruise-In IX Veteran
The best side pipe mufflers are JCL's turbo baffles. Here is his site.
http://www.spiralturbobaffles.com/
I think I may go for the spiral baffles how do they sound the glass packs are too loud for me.
Worship did u end up fixing the leak? Mines the same way just one side the other one has a slight leak but not really noticeable makes it a real bitch to clean and sounds crappy.
The spiral inserts are the only way to go and not loose power if you are running a high HP engine. The downside is that they are as loud if not louder than glass packs. I have been working on a solution for a month now trying to quiet my big block with out killing power, my current solution is a 3" x 32" glass pack with steal wool packing and a car chemisrtry 2 disk insert in the collector, it is as quiet as the 2" glasspack from hooker but its killing some power with the 2 disk insert.
As for the leaky header, not to be the one with bad news, it needs to be replaced if its chrome. I had a leaky one aswell and there is no way to weld it. Look on ebay for another set cheap.
Good Luck!
Good Luck!
Syco79: Nope, did not fix the leak yet, managed to reduce it, but it's still there on the bottom. Thinking of hammering it some more after a long drive. Bend it when it's hot
wrc69v: the leak is where the pipe slips over the collector. With the engine running you can feel puffs of exhaust escaping from the pipe edges.
Got my H-headers used and they wll need to be refinished.
Before that will fit and test.
Anyone ever weld pipes to headers? can they be removed reinstall if this is done?
Option of servicing STS baffles would be gone! Hmmm?
Go down to your local parts store & buy a tube of Permatex ultra copper or red silicon. Put a few beads over the surface area of the collector, slide your side pipe back on. Make sure you have the silicon thick enough to fill any voids. When you push it over, it'll ooze out everywhere. Wipe the excess off with Prepsol or Bug & Tar Remover. Let it dry overnight so it can set up well before you start the car.
Dean
Dean
The problem i ran into trying to fix my first set of leaky headers was that they are chrome nad you would need to grind away the crome then weld the area, which obviously will not be chrome when your done.
The other problem i ran into is that it usually leaks in the middle of where the four pipes come together in the collector, if you could get a welding gun and wire into the collector to the middle of where the pipes come together you may be able to fix it?
Good Luck, My bet would be on another set off ebay!
St. Jude Donor '05, '09, '15
I'm using the 3" core version of these. I like em!!!!!
"Sidepipe Insert Mufflers - popular on Corvettes & some Cobras.
The expanded ends slip just inside a 4" OD sidepipe - slots cut into each end can be tweaked slightly in order to keep constant tension against the inside of the sidepipe during exhaust heating & cooling cycles. This eliminates rattling & loose fits. Now you can have the unique chambered sound & superior flow through your sidepipes.
NOTE: 2.5" core versions are quieter than 3" core versions.
*These can be made in different lengths as well - inquire."
IN/OUT PART# CORE BODY DIA. BODY LENGTH OA LENGTH
4" 2530-IN 2-1/2" 3-1/2" 26" 33-1/4"
4" 3030-IN 3" 3-1/2" 26" 33-1/4"
http://www.classicchambered.com/index.html
some good ideas I think the Permatex silicon will be a perfect fix just need new mufflers before I do it. I would imagine it wont be easy to take off. My pipes are jet hot coated not that it matters much
Come to think of it, I might have an extra SBC Hooker sidepipe header I would be willing to sell. Its chrome, I have both sides but the pipe got stuck on one and i had to cut the collector to get it off. I will have to check and be sure that the collector is in sound shape so you are not in the same position.
PM me if you are interested and let me know what side you need. Any luck and it will be a match.
Usually i will wait untill the next day after driving if i need to pull of the side tubes, which i have had to do more times than i want to remember-i take my propane torch and head up the slip on tubes (only the area around the collector ) untill you stop hearing the metal expand, its a slight cracking noise. Then with a pair of very grippy leather mechanics gloves just tug and wiggle the pipes and they eventually inch loose. Try to keep your doors open when you are pulling the pipes off seems to give you more leverage.
It is never easy and I bitch about it the whole time
Location: Part breakage is just weakness leaving my Stingray
1 Post
the JCL baffles certainly will have the least restriction, but if you're worried about the noise then you'll want to use something else.
I love mine, but they do sing a song.
