Q-jet electric choke question
Old 03-24-2008, 09:29 PM
champs65
champs65's Avatar
Default Q-jet electric choke question
My SB 69 has a later electric choke q-jet on it and a weiand intake with the choke coil plate blocked off.
How does the electric choke work? Does the single spade on the choke take continuous or intermittent 12V, and what signals it to open/close?
Do I just wire a 12V positive lead to it
Old 03-24-2008, 10:32 PM
SIXFOOTER
Support Corvetteforum!
SIXFOOTER's Avatar
It needs switched 12volts. You can use the Yellow wire on the wiper motor
Old 04-03-2008, 06:59 PM
EVIL_GRIM
EVIL_GRIM's Avatar
i have a question about this also. is it possible to use the open spot on the fuse panel that says IGN? i have a 79, one IGN is occupied by a pink wire, the other is free to use (assuming it gets power)
Old 04-03-2008, 07:13 PM
SIXFOOTER
SIXFOOTER's Avatar
That will work fine
To Q-jet electric choke question
Quick Reply: Q-jet electric choke question
