Is it possible to 'wash' all debris from a fuel tank without...
Possible - Yes. Realistic - Probably not. If you want it completely clean you probably need to drop the tank. If you need it completely clean...
And you would probably get much better answers on a Nova forum, FWIW.
Do you have a bottom drain? Or a bottom fuel sending unit hole? If so, then yeah, it's quite easy. I've done mine and I last did a couple of months ago. Just make sure you dry it well. Of course my 68 has a big hole on top where I can put a hose in there and wash it all out.
Joeclams (05-07-2021)
Dr. Detroit
Received 3,892 Likes
Wash the tank with white vinegar.......vintage motorcycle trick.......fill it as much as you can and let it sit 24 hours. Drain and stare in amazement.
Jebby
Jebby
