Electric fuel pump mounting????
Old 02-24-2008, 11:19 AM
RHBROWN
RHBROWN's Avatar
Default Electric fuel pump mounting????
Im going to start cleaning up the engine on my new (to me) 75. The car has a holley red pump mounted to the right inner fender. I want to relocate it to the rear but not sure where to put it. Can yall show how and where yall mounted your fuel pumps. What are using for fuel lines?? I also wanted to switch to AN fittings and braided fuel line. Thanks for the help guys.
Old 02-24-2008, 11:50 AM
rosslato
rosslato's Avatar
i mounted mine on the rear frame brkt, shoulda put it on the front brkt under the gastank but if i'm rearended i'm screwed anyhow. i included a shutoff valve w/#6 AN fittings and also have a on/off switch mounted under the dash.
Old 02-24-2008, 04:01 PM
RHBROWN
RHBROWN's Avatar
The problem I have is the 75 gas tank pick up is on the side of the right side ofthe tank.
Old 02-24-2008, 08:17 PM
pef427
pef427's Avatar
I mounteed it to the tank support but went back and installed a 1/4" piece of rubber between the pump and mount to quieten it down some.
-Patrick
To Electric fuel pump mounting????
Quick Reply: Electric fuel pump mounting????
