Banging noise from drivetrain
Old 02-17-2008, 09:56 PM
scott3392
scott3392's Avatar
Default Banging noise from drivetrain
I have a 75 just had the transmission rebult with a shift kit put in (400 turbo) when I put in reverse I hear a banging noise when I put in drive noise is still there but not as loud.When under way car drives fine no noise or vibrate.But I did notice when I put in gear the car squats & raises more with new trans.p.s. rear end is topped off with new fluid & 1/2 shafts fill tight.Thanks scott
Old 02-17-2008, 10:10 PM
DIP51
DIP51's Avatar
2018 C2 of Year Winner
Check the bushing on the front of the differential. If it is cracked/worn, it will cause the banging.
Old 02-17-2008, 10:36 PM
scott3392
scott3392's Avatar
Default On order has arrived
Thanks I was hopeing someone would say that,I'm gone 3 weeks at a time will be home Tues have new ones there now.I been it was not the rear end just started at once car has not been ragged
Old 02-17-2008, 10:58 PM
ENG40
ENG40's Avatar
Did you put additive in the rear end (if it's a posi) when you changed the fluid?
Old 02-18-2008, 08:34 AM
GTR1999
GTR1999's Avatar
Received 2,612 Likes on 1,336 Posts
The banging at low idle could be the improvement to the TH400. I rebuilt my 400 and set it up to the street/strip mods. The added pressures cause a bang noise when I let the car slowly drive and shift in idle, like in a parking lot. Normal driving and it's fine. This may be your noise? Posi hammering will usually show up starting up from a corner, when the clutches won't slip enough and hammer. I can fix that too but you have to pull the posi case.
Old 02-18-2008, 09:00 AM
scott3392
scott3392's Avatar
Default Thanks Guys
I appreciate all your input & your time my 75 is a restore frame up (78 frame) wish I had talked to you guys a year ago Thanks again Scott
To Banging noise from drivetrain
Quick Reply: Banging noise from drivetrain
