How to disable the alarm
Old 02-01-2008, 07:00 PM
cargo247
cargo247's Avatar
Default How to disable the alarm
Hi all
Need a little help here with my 81s alarm system, the thing is it does not work I was told this when I got the car they had pulled the courtesy light fuse and he said all was well after they did that, but I like courtesy lights so after hr upon hr of trying to get this to work can someone tell me how to disable the alarm and have courtesy lights and everything else working just not that dam alarm.
Hope everyone got around ok in the snow!
cargo247 is offline
Old 02-01-2008, 08:41 PM
SIXFOOTER
Support Corvetteforum!
SIXFOOTER's Avatar
Here are the schematics for the alarm.
What does the alarm do on your car?
If the alarm module is bad I think all you have to do is unplug it.
Here is the alarm operation page
SIXFOOTER is offline
Old 02-01-2008, 09:15 PM
cargo247
cargo247's Avatar
Wow
Thanks for all that info , from the looks of it I can just pull the
Control module without causing any other problems in the car? Yes/no?
One thing it does is locks out the starter.. sometimes?? Horns go off when I put the key in the door ect ect I don’t need that alarm as I will be installing an after market, any thoughts….
cargo247 is offline
Old 02-01-2008, 09:27 PM
cargo247
cargo247's Avatar
where is the Control module located?
cargo247 is offline
Old 02-03-2008, 08:24 AM
DO2G
DO2G's Avatar
On my 78 I pulled the alarm relay. It is located under the center console on the driverside. It has yellow, orange and blue wires going to it.
Not sure if your year would be the same.
DO2G is offline
Old 02-04-2008, 12:41 AM
danno12345
danno12345's Avatar
Default Yeah, the alarm... ;)
I had some adventures with my alarm too.. Finally just unplugged the thing. On an 81, it's in the passenger side rear compartment. There's the wiper delay module & the alarm back there. Wipers are the smaller component. Just pull out the big plug & you're off to the races.
Stupid starter kill... Made me leave the car in a Wendy's parking lot overnight once. I called up the PO to ask how to reset the alarm. Response: It has an alarm?
Good luck!!
danno12345 is offline
Old 02-04-2008, 05:46 PM
cargo247
cargo247's Avatar
Good luck!!
passenger side rear compartment? someone told me i would have to open the center console to get to the module for the alarm. this is much
easier, the larger of the two just unplug it?
cargo247 is offline
Old 02-04-2008, 07:52 PM
KENS80V
KENS80V's Avatar
looks like the 78 to 80 cars are different. They don't have anything to do with the starter and there is only one arming switch (drivers door). My schematic for the 80 Corvette is much different then the 81.
KENS80V is offline
Old 02-04-2008, 08:21 PM
danno12345
danno12345's Avatar
Yup, the big one in the compartment. The next page of the Shop manual shows it, but I don't have a scanner.
In the older cars it was in the console, but in '81,it's back there.
Dan
Old 02-05-2008, 01:41 PM
cargo247
cargo247's Avatar
Dan
Thanks Dan
I will rip that baby right outa there.
cargo247 is offline
Old 12-01-2020, 04:58 PM
Steve Kaysoe
1st Gear
Steve Kaysoe's Avatar
mine just kept on going off speratically. Very annoying in traffic!!! the solenoid trick in the pax rear com partment seems to have done the trick!!! THANK YOU!!!
Steve Kaysoe is offline
To How to disable the alarm
Quick Reply: How to disable the alarm
