GM 502 crate motor owners manual
Old 12-28-2007, 11:39 AM
rajsid
rajsid's Avatar
Default GM 502 crate motor owners manual
Does anyone know how I can obtain an owners manual for a GM 502 crate motor?
My 69 vette came with a 502 motor with the block-Part number-10237300. The previous owner put it in, but he does not have the owners manual with him anymore.
I have tried calling GM performance and Helm without much success.
Old 12-28-2007, 11:45 AM
rajsid
rajsid's Avatar
Default Unbelievable
I just got off the phone with GM performance parts (again).
The representative asked me what kind of car the motor is in right now.
I said that it was a 502 crate motor and it does not matter which car it is in. After 3 minutes of hold, she very confidently told me that GM does not make 502 motors anymore
Old 12-28-2007, 12:23 PM
Durango_Boy
Durango_Boy's Avatar
Try calling again, and if you have trouble getting your point across, ask to speak with an area manager. They, if nothing else, should be able to point you in the right direction.
Old 12-28-2007, 02:52 PM
standup
standup's Avatar
I asked for a manual when I bought my 454HO a year ago and I was told there wasn't one.......nothing came with the motor except some GM Performance stickers and a single page about the warranty, which is null & void because it's an export.........
As for GM not making 502's anymore: BWWWWWAHAHAHAHAAAAA !!!!!!
Old 12-28-2007, 04:48 PM
markdtn
markdtn's Avatar
I didn't know there was an owners manual? You might try Scoggin-Dickey or one of the dealers that sell them and see what they say.
Old 12-28-2007, 05:11 PM
rajsid
rajsid's Avatar
Not sure if it's called an owners manual or service manual. Usually crate engines should come with detailed engine specs and maintenance instructions. I will try Scoggin-Dickey
Old 12-28-2007, 05:18 PM
Skunkvette
Skunkvette's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I bought a 502/502 from Scoggin Dickey last year, the engine did not come with ANY paper work, not even a "This Side Up" installation sticker.
I spoke to GMPP and Scoggin Dickey directly and they stated that that is the way they ship. No manual, no dyno sheet, no break in recommendations.
Old 12-28-2007, 05:32 PM
rajsid
rajsid's Avatar
Very Interesting...
How did you find service information for your motor. By service information, I mean the following.
Recommended oil
Suggested spark plug
Spark plug torque specs
etc..
Even if the motor does not come with a service manual, it should be available for purchase.
Old 12-28-2007, 05:53 PM
rajsid
rajsid's Avatar
Just called Scoggin Dickey. The sales representative that I talked to said that GM does not sell service manuals for their crate motors. It's available only for GM dealerships, which means that you have to have your crate motors serviced by the dealer.
*****n unbelievable.
Old 12-28-2007, 05:58 PM
Bullshark
Bullshark's Avatar
CI 5 & 8 Veteran
My RamJet 502 came with a "RamJet 502 System 12497323 Specification". It has a GM part# 12486609. Consists of 7 stapled, double sided pages of System description, specifications, installation procedure, break-in, and parts list. Not much in the way of detail.
Bullshark
Old 12-28-2007, 06:00 PM
Skunkvette
Skunkvette's Avatar
Originally Posted by rajsid
Interesting...
Recommended oil
etc..
Talked to my local engine guru for oil recommendation - Valvoline Racing (high in zinc)
Engine came with spark plugs installed (I have never used a torque wrench for spark plugs). Checked factory preset gap when they were pulled for installing headers and dialing in bell housing.
Cross referenced oil filter off of part number on the one installed at the factory.
Specs for engine are availble on line. Thanks for the part number Bullshark!
Old 12-28-2007, 06:30 PM
rajsid
rajsid's Avatar
Thanks to both of you Skunkvette & Bullshark
A couple of last questions.
What's the spark plug gap that you have set ?
What kind of spark plug cables do you use.
I am trying to do a full tune up and I am so annoyed by the fact that GM does not give out service information for these crate motors
Old 12-28-2007, 07:11 PM
Bullshark
Bullshark's Avatar
CI 5 & 8 Veteran
RamJet specification document calls out "AC Delco Rapidfire #4" part#25164642 you might look up that part for gap setting????
Parts list calls out the following GM part number #12368383 - Spark Plug Wire Kit (7MM wires).
Bullshark
P.S. this info is for the zz502 and RamJet aluminum head engines
Old 12-29-2007, 12:33 AM
FB007
FB007's Avatar
.035" for coils, .045 for HEI.
Old 12-29-2007, 01:07 AM
rihwoods
rihwoods's Avatar
I can copy my ZZ502/502 "Installation Instruction" package for you, but mine is the 12371204 kit(Long block) Aluminum heads,etc....I would think most torque specs,etc same as yours maybe....(parts list different though)..
Here is link to Service Manual for the 502 Ram Jet:
http://www.crateenginedepot.com/stor...4-P1251C6.aspx
Rich
Old 12-29-2007, 09:53 PM
rajsid
rajsid's Avatar
And I found a couple of other books that may help.
http://www.amazon.com/gp/reader/1557...46#reader-link
Old 12-29-2007, 11:57 PM
rihwoods
rihwoods's Avatar
Yeah,the Rat motor book may help...Just use common sense when it comes to maintenance...in otherwords, when in doubt,change the oil...
To GM 502 crate motor owners manual
Old 12-30-2007, 12:18 AM
rajsid
rajsid's Avatar
Here is a not so related old timer saying.
"If it aint leaking.. There is no oil in it"
Old 12-30-2007, 01:32 AM
Ironcross
Ironcross's Avatar
Default Try This,
About the closest article or catalogue information on the crate engines is the "GM Performance Parts" catalogue. The 2001 version part number is PP NO. 13, P/N 12497881. I believe available in book stores.
Old 12-30-2007, 01:59 AM
stingr69
stingr69's Avatar
Received 1,039 Likes on 805 Posts
The GM Performance Parts Catalog is free to download from the web but it is a 38 meg PDF file so dial up users beware.
-Mark.
Quick Reply: GM 502 crate motor owners manual
