O2 location
O2 location
Anyone know the correct clocking for a 4 wire heated O2 sensor? I'm installing the bumg in the reducer aft of the header collector. Should I install it straight up or on the side level with the pipes? Thanks
Install it at the 3 or 9 0'clock position. You do not want it at the 6 o'clock position due to moisture settling in the pipes. Mine is at the 3 o'clock position as are most factory O2 sensors.
