Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-05-2007, 08:19 AM   #1
AWilson
CF Senior Member
AWilson's Avatar
Default Pressed vs. bushed connecting rod ends
RELATIVE TO MY LESS THAN 400 HP 383 BUILD. Is there any preference or REAL advantage of either pressed and bushed connecting rods.
AWilson is offline   Reply With Quote
Old 12-05-2007, 08:37 AM   #2
houstonvett
CF Senior Member
St. Jude Donor '09
Support Corvetteforum!
houstonvett's Avatar
The bushed rods are a full floating design which lets the piston wrist pin turn in the rods end. The floating design is really for high revs which cuts down on the G forces on the wrist pin. If you aren't going to be turning high RPMs there wouldn't be much difference between the pressed rod and the full floating one IMHO, houstonvett
houstonvett is offline   Reply With Quote
Old 12-05-2007, 08:40 AM   #3
Stroker-427
CF Senior Member
Stroker-427's Avatar
Unless you will use Forged or Hypereutectics pistons...... no way to go with floating pins!
Anyway, for my opinion, due to the very good price of today's Hyp. Pistons there is no reason to stay with the cast ones...... so go with floating !
A very few horses..... but much more reliables.... keep in mind that a stroker SBC will have higher side loads at the pistons !
Stroker-427 is offline   Reply With Quote
Old 12-05-2007, 09:50 AM   #4
AWilson
CF Senior Member
AWilson's Avatar
Ok, so far the score is even!
Old 12-05-2007, 09:59 AM   #5
jimvette999
CF Senior Member
jimvette999's Avatar
I vote for forged pistons and floating wrist pins...you may add a power adder later (NOS). Floating pins also make for an easier rebuild. Hypers are a bit brittle IMO, better than cast, not as safe as forged.
jimvette999 is offline   Reply With Quote
Old 12-05-2007, 10:37 AM   #6
Wrencher
CF Senior Member
Wrencher's Avatar
Every engine I build for myself has forged pistons and full-floating piston pins. You'll get folks saying it is not needed for a mild street engine and they are right, plus it is expensive to go that way, but every little bit helps and I go for bulletproof every time on my stuff.
I'm partial to Venolia or Keith Black, depending on the application
Hans
__________________
The Larry Shinoda Collection: '69 L-68, '70 BOSS 302, '65 & 67 Corvair Monzas... http://www.corvetteforum.net/c3/wrencher/
In progress: '88 GTA, 425/409 2x4 (looking for a '62...)
Wrencher is offline   Reply With Quote
Old 12-05-2007, 11:25 AM   #7
Manuel Azevedo
CF Senior Member
Manuel Azevedo's Avatar
Quote:
One part depends on the piston you decide to use cause they will have to have snap right grooves in them to retain the pin. (though there are teflon buttons also but only should be used in all out raceing) If your useing stock type rods it probaly will not be worth modifiying the rod for floating pins and if you do anyway don't go metal to metal have them bushed. There is "0" horse power in floating pins but they will spread the load wear out over a bigger surface.
Manuel Azevedo is offline   Reply With Quote
Old 12-05-2007, 11:33 AM   #8
DRIVESHAFT
CF Senior Member
DRIVESHAFT's Avatar
Unless you take your engine apart a lot, there will be no advantage to floating pins.
It is just one more "wear item" in the engine. I vote pressed.
DRIVESHAFT is offline   Reply With Quote
Old 12-05-2007, 12:01 PM   #9
AWilson
CF Senior Member
AWilson's Avatar
Ok, pressed pins it is. Do my pistons have to accept pressed pins or do they all? My pistons are off the shelf Weisco.
Old 12-05-2007, 12:48 PM   #10
Scott Marzahl
CF Senior Member
Scott Marzahl's Avatar
Most if not all pistons can be used with pressed rods. For a street car I vote the conservative pressed pin for dead on reliability. Yeah you can do double spiro locks etc, but if it's not being torn down on a regular basis why take the chance.
Scott Marzahl is online now   Reply With Quote
Old 12-05-2007, 12:50 PM   #11
bashcraft
CF Senior Member
bashcraft's Avatar
There is no hp gains. The only advantage is disassembly.
bashcraft is offline   Reply With Quote
Old 12-05-2007, 01:14 PM   #12
lars
CF Senior Member
lars's Avatar
Location: At my Bar drinking and wrenching in Lafayette Colorado
I have had several failures of floating pins used in street applications: The single bearing point at the pin bushing location will fail in a floating setup if the engine is exposed to any amount of detonation (not uncommon to occasionally occur with pump gas). For trouble-free and reliable street service, I only use pressed pins.
lars is offline   Reply With Quote
Old 12-05-2007, 02:04 PM   #13
Belgian1979vette
CF Senior Member
Belgian1979vette's Avatar
My rods required me to use floating pins.
Belgian1979vette is offline   Reply With Quote
Old 12-05-2007, 02:12 PM   #14
AWilson
CF Senior Member
AWilson's Avatar
My pistons can be pressed or bushed. So I will go pressed for reasons stated by others above.
Thanks everyone.
Old 12-05-2007, 05:56 PM   #15
Wrencher
CF Senior Member
Wrencher's Avatar
Quote:
I should qualify this a little. All the previous post are correct. The main reason I do it is the RPM ranges my engines see. The BOSS is safe to 7900, the vair to 7200 and the 409 should handle 6800, which is a bunch with those heavy pistons. When I do the 427, I'll build it with the same intentions. A that point, floating pins are the way to go for me.
Hans
__________________
Old 12-05-2007, 11:50 PM   #16
jackson
CF Senior Member
For a motor like that ... there's no performance advantage to float ... the only other TWO advantages to float are ease of assembly & no press-stress on pistons. However ... wrangling 4 CONVENTIONAL spirolocs per piston can get a bit tedious ... wirelocs much easier ... floaters will have some sort of pin loc that must be installed.
Many pistons are dual-use ... But I've never seen a dual-use rod.
AFAIK ... you must float pins if rods are bushed.
jackson is offline   Reply With Quote
Old 12-06-2007, 12:20 AM   #17
Ironcross
CF Senior Member
Ironcross's Avatar
Whether you know this or not, both the L88`s and Z`s 302`s have full floating pins. Do you still object to there use now?..
I better add the ZL1`s too before someone complains.,
You use Nylon buttons as pin locks, thats what I use on the race engines
Ironcross is offline   Reply With Quote
Old 12-06-2007, 07:06 AM   #18
bashcraft
CF Senior Member
bashcraft's Avatar
Hans
I'm missing your point. What advantage do floating pins have at a higher rpm? My 350 will turn 8200 all day with pressed pins.
Old 12-06-2007, 07:12 AM   #19
bashcraft
CF Senior Member
bashcraft's Avatar
Quote:
The only time there is "press stress" on the pistons is when the pins are pressed out to remove them. At this point, the pistons will be replaced.
To install the pins, the small end of the rod is heated until the pins will slide in with no resistance, then allowed to cool to return the press fit. No stress at all.
Old 12-06-2007, 07:16 AM   #20
bashcraft
CF Senior Member
bashcraft's Avatar
Quote:
I don't think anyone is objecting to their use, well, maybe Lars is, but why add the expense when there is nothing to gain?
Reload this Page Pressed vs. bushed connecting rod ends
Tags
bushed, bushes, bushing, c3, connecting, correct, corvette, ends, floating, pin, press, pressed, rod, rods, size
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
