Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-25-2007, 01:31 PM   #1
Le shark81
CF Senior Member
Le shark81's Avatar
Default Need help with my cog belt install (pics inside)
I got a Black Mountain Precision 2" Cog belt kit for short water pump SBC a while back.
I've faced some issues (belt is too long, center holes needed to be enlarged..) but the biggest one being I can't align the power steering pump.
The Crank pulley was delivered with a V-groove pulley in the front for P/S. It doesn't worked.
I then relocated it at the back. Same problem.
I'm so pissed off I'm considering buying standard pulleys...
Too bad, because I've spent some money to get them and have them adapted and I love the way they look.
I've seen at last 2 Corvettes on this forum with this setup.
Does anyone know how to solve this ? New bracked ? New P/S pump ?
Here are the pics:
Le shark81 is offline   Reply With Quote
Old 11-25-2007, 03:08 PM   #2
CorvetteDave01
CF Senior Member
Support Corvetteforum!
CorvetteDave01's Avatar
Sorry I can't help, but I am interested, that is a cool setup. I just dealth with converted some alum. V-belt pulleys and it was a pain. I don't see how your going to get the V-belt to work on the PS pump though. It can't go much further forward due to crossmember clearance and can't go back or it's going to hit the pump.
CorvetteDave01 is offline   Reply With Quote
Old 11-25-2007, 05:24 PM   #3
hemorrhage22
Junior Member
hemorrhage22's Avatar
Just curious ... is this set up just for looks ? or are there any advantages ?
hemorrhage22 is offline   Reply With Quote
Old 11-25-2007, 05:54 PM   #4
TPI BOY
CF Senior Member
TPI BOY's Avatar
TPI BOY is offline   Reply With Quote
Old 11-26-2007, 01:52 PM   #5
Le shark81
CF Senior Member
Le shark81's Avatar
Quote:
It is designed to avoid stock V-belts to fly off in hi-revving engines.
In my case, it's just for the look
Old 11-26-2007, 02:15 PM   #6
neuroclast
CF Senior Member
neuroclast's Avatar
Send a message via AIM to neuroclast Send a message via MSN to neuroclast Send a message via Yahoo to neuroclast
Not to hijack or anything, but that bracket for your alternator, where did you get it? My bracket broke and because of my tall valvecovers it's been a pain getting the belt to not squeal.
-Josh
neuroclast is offline   Reply With Quote
Old 11-26-2007, 02:19 PM   #7
Le shark81
CF Senior Member
Le shark81's Avatar
Quote:
-Josh
It's a March Bracket. I got it at Summit.
Old 11-26-2007, 02:27 PM   #8
yellow 72
CF Senior Member
St. Jude Donor '09
yellow 72's Avatar
If you're gunna go through all the trouble to run a cogged belt, why not have it spin something exciting?
yellow 72 is offline   Reply With Quote
Old 11-26-2007, 02:56 PM   #9
rosslato
CF Senior Member
rosslato's Avatar
-Josh
u can also get them from March in all different sizes my bad, your talking brkt and i'm talking the ext arms.
rosslato is offline   Reply With Quote
Old 11-26-2007, 04:55 PM   #10
lvrpool32
CF Senior Member
lvrpool32's Avatar
Send a message via AIM to lvrpool32
If the pulley was at the front of the cog, I would say it is designed for the later remote reservoir style power steering pumps, not the saginaw style.
The other theory, maybe this kit was designed for a long waterpump...but that would mean the crank cog wouldnt line up then.
where did you get the kit from?
edit--looks like this kit from ebay...
http://cgi.ebay.com/ebaymotors/Hi-Pe...QQcmdZViewItem
thats a long waterpump on that motor.
Nick
__________________
1969 Retro Road Race Coupe. A tribute to the Heinz and Johnson #4 race car.
64 Bucik Riviera (425 Nailhead)
1993 Dodge Viper RT/10
Team in Training - The Leukemia and Lymphoma Society
lvrpool32 is offline   Reply With Quote
Old 11-27-2007, 04:09 PM   #11
Le shark81
CF Senior Member
Le shark81's Avatar
I got my kit from the same source but ordered mine for a short water pump...
Anyway I think I'll design a new bracket reusing some parts of my March bracket to move my P/S pump backward and a little outward.
Hope it'll be OK
Reload this Page Need help with my cog belt install (pics inside)
Tags
belt, black, cog, corvette, mountain, precision, pulleys
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
