1980 Accessory Pulley questions
Location: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
How many grooves should there be on the water pump and crank pulleys? My AIM says three each. My car has a 2 groove on the water pump currently, but it's out of round and needs replaced. This winter I'm putting the Smog pump on my car and think I need the third groove on the water pump to make it all work. I can't find anyone that even sells a 3 groove short water pump pulley.
The AIM also shows the that the most forward groove on the crank pulley should be smaller and connected to the P/S pump. Is that correct, because that's not what is on my car. From memory, all three grooves are the same diameter.
Can anyone provide me with any pictures of the correct pulley set up with the smog and A/C connected.
Thanks.
Thanks.
I have a 80 and will check. A couple of yrs. ago I installed Spal electric fans and done away with the air pump. If memory serves me right its only a 2 belt pulley with seperate single pulley bolt on addition to make it 3. At work right now so it won't be till late this evening till I can check.
I'm so confused by this because I can't seem to find anything to document it.
Both crank and water pump 3rd grooves are add ons.The one on the crank for the PS is smaller.
http://www.corvette-paragon.com/cata...4-5BE6E37FC45B
http://www.corvette-paragon.com/cata...7-482B0184FAC1
Thanks for clearing this up. I now know that I have more problems than and out of round pulley. I also have the wrong size. Mine is a 7 1/8" OD pulley based on the part number. I should have a 6 1/4" OD pulley stock. So, would this explain why my alternator seems to be on the high side of the voltage range?
