Radiator Support Brace on a '77
Noticed I've got some rust with holes on the brace on the side of the support that faces the back of the car but the bottom of the brace is still solid and and corners look to be in good shape. Cleaned with a wire brush and painted but I'm concerned about it being weakened. Any thoughts on bolting on a bar to support it verses having to remove and replace?
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I bought a new one from GM for my '76 a few years ago for about $275 or so. I don't know if they are still available or not. I'd replace it if I were you.
I'd take a awl and try poking it in those lower sections and corners to see just how solid it is. That is a major support structure for the front of the car. I also cut out the rot and welded in new pieces.
St. Jude Donor '07
I built a new one using angle iron and the top of the old one. I don't recommend it, and if I hadn't been going with a non-stock A/C condenser I probably would have just bought a new one for $350.
Luckily only the back half of mine is sketchy. I've started forming out of 16 gauge... since I've got a few sheets of that around. Rig is out of welding gas, and got .040 flux core to use...
Come one, someone tell me a harder way to do this project!
Good news is, 16 gauge won't rust out any time soon.
St. Jude Donor '07
