Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-17-2001, 12:12 PM   #1
rainman69
CF Senior Member
rainman69's Avatar
Default Stock "Camel Hump" flow?
Does anyone have flowbench numbers for a set of -186 "Camel Hump" heads?
Thanks in advance. :smash:
rainman69 is offline   Reply With Quote
Old 11-17-2001, 01:16 PM   #2
SteveG75
CF Senior Member
SteveG75's Avatar
Default Re: Stock "Camel Hump" flow? (rainman69)
Try http://www.chevyhiperformance.com and the Cyber-Flow link. They have a lot of flow info there but I am not sure about the the -186's.
SteveG75 is offline   Reply With Quote
Old 11-17-2001, 03:09 PM   #3
Rowdy Rat
CF Senior Member
Rowdy Rat's Avatar
Stans.Corvette.Restoration
Stock "186" heads with 1.94"/1.50" valves and no modifications whatsoever flow right around 180cfm/121cfm (at 25" of water and .485"/.450" of valve lift). A good three angle valve job, backcutting the valves and increasing valve size to 2.02"/1.60" will get you up around 206cfm/155cfm... At least according to David Vizard's testing.
Any luck with photos of your clutch assembly? I've talked to a couple of owners of original cars since that thread was active and they swear that the 11" clutch/14" flywheel was what was installed in their cars... If your 10.4"/12.75" setup was originally installed in your car, you might have a real oddball there!
Regards,
Rowdy Rat is offline   Reply With Quote
Old 11-17-2001, 04:10 PM   #4
MassVette
CF Senior Member
MassVette's Avatar
Try GM performance parts--they have a complete chart for all the SB and BB Chevy heads. And I believe these heads weren't near the top, but check it out. Seems to me the Vortec and SB II heads were quite high in flow, according to GM---
:yesnod: :chevy :chevy :chevy :yesnod:
MassVette is offline   Reply With Quote
Old 11-18-2001, 05:45 PM   #5
rainman69
CF Senior Member
rainman69's Avatar
Default Re: Stock "Camel Hump" flow? (MassVette)
So, I tried http://www.chevyhiperformance.com/ and I can't get to it. It just keeps reloading the page every second or so. What the heck???
Thanks for the info so far, I'll keep looking. :smash:
Old 11-18-2001, 06:30 PM   #6
Stingy74
CF Senior Member
Stingy74's Avatar
Send a message via MSN to Stingy74
Back in the day a friend of mine ran 10.15's in a super gas Vega he built from scratch. He was young and poor and used a set of double bumps that he had heavily ported. They must have flowed good to be that fast but then again the car only weighed 2200 pounds and made up for lost power elsewhere. That's a while ago but he consistantly tells me he would have run 9.40's or better like everyone else, had he had better flowing heads and a Lenco transmission and stuff. I'm assuming you could probably get them to flow like 250 or something but that's completely a guess. Most enlarged port race heads flow close to or over 300 cfm.
Stingy74 is offline   Reply With Quote
Old 11-18-2001, 07:09 PM   #7
rainman69
CF Senior Member
rainman69's Avatar
Default Re: Stock "Camel Hump" flow? (Stingy74)
Can anyone get to these charts? GM Performance Parts was rather worthless unless you know the part number as far as I could find.
http://www.chevyhiperformance.com just won't open. So, if anyone else can get to these charts and email them or post them (text preferred)...
Old 11-19-2001, 01:00 AM   #8
SteveG75
CF Senior Member
SteveG75's Avatar
OK, my bad, got to go to Best of CHP Engine Tech, then Engines, then Cyber Flow to Go. And they don't have a listing for the 186 heads. Probably the closest is the 462 heads which ere used on 327's thru 1968.
462 heads:
Lift Intake Flow Exhaust Flow
0.050 18 27
0.100 50 54
0.200 119 88
0.300 167 116
0.400 198 128
0.500 212 134
0.600 218 137
Hope this helps. Should be fairly close.
Old 11-19-2001, 01:19 PM   #9
Rowdy Rat
CF Senior Member
Rowdy Rat's Avatar
The Chevy High Performance flow numbers were measured at 28" of water... The test numbers in David Vizard's books are typically taken at 25" of water. The CHP numbers will be higher as a result.
Just something to keep in mind when looking at flow test data. :)
Regards,
Old 11-20-2001, 10:41 PM   #10
adam
CF Senior Member
adam's Avatar
Vizard's Book How to Build max performance SBC, says:
(reading from a graph)
186's @ 28 in h20
lift intake exhaust
100s 44 60
200s 75 110
300s 112 160
400s 125 180
500s 135 190
600s 140 191
700s 143 192
Pg. 84 Fig 9-4.
adam is offline   Reply With Quote
Old 11-21-2001, 01:42 AM   #11
Dino_'72
CF Senior Member
Dino_'72's Avatar
Default Re: Stock "Camel Hump" flow? (adam)
Check out these links for flow numbers relating to various heads. I believe 186s are a similar casting to 462 and 492.
http://www.topher.net/~bearman/gmheadcomp.html http://www.geocities.com/MotorCity/Speedway/5117/flow/ http://www.castheads.com/heads/heads.htm
Dino.
Dino_'72 is offline   Reply With Quote
Old 11-21-2001, 10:29 AM   #12
Rowdy Rat
CF Senior Member
Rowdy Rat's Avatar
David Vizard seems to be one of the few people still interested in testing the older original engine parts as well as the current offerings. He has put together some great books over the years and I would recommend reading ANYTHING he has written.
I went back through his book How To Build And Modify Chevrolet Small Block V8 Cylinder Heads last night (where I found the original flow numbers that I posted) to see what else I could turn up... Ran across a sidebar on page 66 that noted while the flow numbers in the book were taken at 25" of water, it was possible to convert pressure drops to allow direct comparison of flow numbers. The formula that David Vizard gave was:
[(New Pressure Drop/Old Pressure Drop)^(1/2)] x Flow at Old Pressure Drop
For example: going from measurements taken at 28" of water to 25" of water;
[(25"/28")^(1/2)] x Flow at 28"
[.8928571^(1/2)] x Flow at 28"
.9449112 x Flow at 28"
For those interested in making "apples to apples" comparisons of flow numbers taken at different pressure drops, this should be a big help.
Regards,
Reload this Page Stock "Camel Hump" flow?
Tags
186, 191, 462, 492, camal, camel, cfm, chart, david, flow, heads, heaf, hump, humps, numbers, stock, tomahawk, vizzard
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
