68 sb steel fan shroud mtg brackets
I have a 68 vert 327/350 sb manual no a/c
I need help with the mounting brackets to install my steel fan shroud. My shroud is NOS and does not have any brackets attached. There is to be 1 on the top and 2 on the bottom. The 2 on the bottom should have 2 mating brackets in the lower shield, which I also do not have. I have not been able to find these being sold anywhere. I also have not been able to find any used. Does anyone have dimensions and photos so as to help me make my own?
THANKS!!!
THANKS!!!
do you want this like right away?
If you respond, then I'll go do it....mine is removed, I installed an electric fan.....
...by the way, I would recommend the electric fan....it makes the whole area a lot more roomy.
Great! Thanks! I just need the measurements so I can make the needed brackets to get the things mounted. I was thinking of that mod, but I'm sticking to my original plan of trying to keep the car as original as possible, even fixing things along the way done by the prvious owners. Even down to the small things like removing the "Stingray" emblems. My email is bwellisley@yahoo.com
THANKS!!!
THANKS!!!
I've got a couple...
sent them your way....
