Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-05-2007, 02:08 AM   #1
Woodie
CF Senior Member
Support Corvetteforum!
Default C3 ( 1980) frame for a C2 Body?
Does anyone have a blueprint for putting a C2 on a an 1980 frame?
Woodie is offline   Reply With Quote
Old 10-05-2007, 02:14 AM   #2
I'm Batman
CF Senior Member
St. Jude Donor '07
I'm Batman's Avatar
Send a message via AIM to I'm Batman Send a message via Yahoo to I'm Batman
There are a number of smallish changes relating to bumper and body mounts - and a huge change in the rear suspension. 1980 was the first year of the aluminum "bat wing" differential and mount.
There's a site that's been posted here many times detailing the C2/C3 frame changes. A search should turn it up quickly.
http://www.71corvette.com/frames.html
I'm Batman is offline   Reply With Quote
Old 10-05-2007, 02:22 AM   #3
TheSkunkWorks
CF Senior Member
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
I believe this is the one the Bat is referring to...
Amazing, when you think about it, that the C2 and C3 can have so much in common under the skin.
TheSkunkWorks is offline   Reply With Quote
Old 10-05-2007, 07:53 PM   #4
Woodie
CF Senior Member
Thank you for the responses. I probably should have given a little more detail. Several years ago I bought a 65 with a 67 one piece nose ( maybe ecklers) no head light buckets. It has flares, good for bigger tires. A whale tail and it had new paint. I also bought a burnt 80 auto with a beautiful frame. since the 80 is said to be a better handling unit I thought I would take a fresh 961 block 396 I have that is built and put them together with a doug nash 5 speed I have and make a fun car. I don't care if I have to cut the whole rear frame of the 80. And I should be able to sell the nice 65 frame to pay for a bit of the project. My thoughts at the moment anyway.
Old 10-05-2007, 10:07 PM   #5
72LS1Vette
CF Senior Member
72LS1Vette's Avatar
Have you looked at what Vette Brakes has for suspension kits? You might be able to improve the handling of your C2 substantially without having to swap the frame. The front control arms for Vettes are the same from 63-82 and IRS has been around since 63 so there isn't a big advantage to swapping the frame.
Rick B.
72LS1Vette is offline   Reply With Quote
Old 10-05-2007, 10:11 PM   #6
SLVRSHRK
CF Senior Member
SLVRSHRK's Avatar
As part of reducing the weight of the later C3 models, the thickness of the frame was reduced from .110 inches to .090inches in 1980, so the rails themselves are thinner.
SLVRSHRK is offline   Reply With Quote
Old 10-05-2007, 10:48 PM   #7
TheSkunkWorks
CF Senior Member
The biggest plus of most C3 chassis over the typical C2 is the rear kick-up gussets added during the '68 run. Geometry wise, replacing the C2 rear camber strut bracket with at least a C3 piece (if not VB&P's cool bracket) would reduce (you don't want to eliminate it except for drag racing) the excessive camber gain inherent in C2's. Any other improvements you might make to one are pretty much applicable to the other.
Also, the '80-'82 Dana 44 batwing diff isn't quite as strong as the earlier 10-bolt, which can be an issue with high perf engines. Good news is that the latter can be fitted with a little adapting work. Bad news is that 12-bolt IRS diffs evidently don't fit the batwing, should you ever want to go that route.
edit - The C3/D44 batwing can be adapted to accept a 12-bolt IRS diff with a spacer/mid-plate to make up for lack of material.
Reload this Page C3 ( 1980) frame for a C2 Body?
Tags
1980, c2, c3, chassis, corvette, fit, frame, wanted
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
