Houston, We have a problem....
St. Jude Donor '09
You're tryin' to pass emissions with this cam?
Good luck
Duration at 0.006" Lift: Intake: 308° Exhaust: 318°
Duration at 0.050" Lift: Intake: 234° Exhaust: 244°
Lift at Cam: Intake: 0.325" Exhaust: 0.340"
Lift at Valve: Intake: 0.488" Exhaust: 0.510"
Timing at 0.050" lift: Open Close
Intake: 10° BTDC 44° ABDC
Exhaust: 59° BBDC 5° ATDC
Centerlines: Lobe Separation - 112° Intake Centerline - 107°
Good luck
Rich
I have a similar situation with my Q-Jet only my HC's are near 3400 at idle. I don't have to pass smog tests here but I had them test it because the thing always stinks of HC's when idling.
Anyway.............the problem turns out to be the idle circuit it the carb is actually lean and it's pulling fuel from another area making the thing seemingly run rich, it's actually running lean.
What carb are you running?
Which head gasket? Which RPM heads: 70cc or 64cc? What pistons? ... and ... How far (if any) down in hole?
