Comp Cams- CS EX274H-10 extreme series.
Old 08-06-2007, 11:19 AM
Tim H
Tim H's Avatar
Default Comp Cams- CS EX274H-10 extreme series.
Anyone heard this cam in a SBC yet.
The web site doesn't really say if its rough idle or what, just good mid range torque. int-487/ex 490, dur 274/286 on a 110 lobe sep.
Old 08-06-2007, 12:08 PM
weimer20
weimer20's Avatar
I'm running that cam in a 383 and it idles with a lope.. Sounds good and it idles below 1000 rpm with no probs at all.
Old 08-06-2007, 01:58 PM
Tim H
Tim H's Avatar
I want a lopy sounding cam, I have the 470/270 Comp cam now and its too tame. Either the 274 extreme or the 480/280 comp cam I think would sound good.
I really like Crane, but their cam site isn't very good compared to Comp so I ruled them out.
Old 08-06-2007, 02:08 PM
The Money Pit
The Money Pit's Avatar
Need to know engine size/specs to even begin a response here. In my 406 the Comp XE-274 idled like a stock 350.
Old 08-06-2007, 02:16 PM
Glensgages
Glensgages's Avatar
I believe CompCams suggests the XE268H as the largest cam to be used with a stock converter, so the XE274H must be pretty radical:
I ran the 292H Magnum (.501"-lift, 244* @ .050", 110* LSA ) on the street with a 'tight' 10"-converter to/from the strip (10.3:1 355" SBC ), and it wasn't that-bad.....
Old 08-06-2007, 03:25 PM
Tim H
Tim H's Avatar
Maybe you do.
Old 08-06-2007, 03:30 PM
Little Mouse
Little Mouse's Avatar
I have a 2006 crane catalog 674 pages thick, crower catalog.
How about this lunati, cam and lifters # LUN-60104LK.
lift 504/525, 276/284 dur, 110 LSA. not hairy enough,
# LUN-60105Lk, lift 525/546 dur. 284/292 LSA 110.
Old 08-06-2007, 04:07 PM
weimer20
weimer20's Avatar
I ran the 274 extreme in my 350 before I stroked it and it was more lopey in the 350. Still able to idle with enough vacuum for the power brakes. I like it in a street motor. I have the same cam in it again but now stroked to 383. I could have and should have gone up a step on the cam when I increased displacement. In a 350, I think you'll really be pleased with it.
Old 08-06-2007, 04:10 PM
Crab
Crab's Avatar
I just ordered the 270H cam from Comp Cams, are'nt you happy with the performance,or just the lack of a lopey idle,or both?
Old 08-06-2007, 05:59 PM
Tim H
Tim H's Avatar
470/270 is a very nice/good cam with a noticable healthy sound to it.
I am just going to pull the engine and trans and do some fun high performance things to it, like a 3500 stall and new 350 race prep trans, heads ETC so I want a lopy cam.
The 470/270 makes alot of power!!!!
Old 08-06-2007, 09:04 PM
Little Mouse
3500 stall, more comp. very good, go for that 2nd lunati, lots of
lift for a 280s duration hydraulic flat tappit cam.
Hell I had a 270 crane in my 350 pickup, stock converter, power
sucking turbo 400, 3.07 rear gears.
Old 08-07-2007, 07:54 PM
ddale1977
ddale1977's Avatar
I have this cam in my 350 auto. The machine shop said its going to 'sound like a corvette should'....(whatever that is). It does sound real good with my hooker sidepipes/headers. Get a lot of complements pulling into a parking lot.
I have honestly been having a little trouble with idle in gear. But, I've been working with Lars on timing and vacuum advance. I ordered a new vacuum advance per his recommendation and hope to correct the idle.
The cam is good off the line but even better about 30 mph and stomp it. I have vortec heads, edelbrock intake, q-jet. 2,500 torque converter. I like the cam just fine.
Good luck, Doug
Old 08-07-2007, 08:25 PM
Tim H
Tim H's Avatar
Good luck, Doug
If you would unplug the vacuum advance, buy some light springs and weights, put your timing at 36 at 2500rpms and about 23 at idle with a dialback timing light you wouldn't have to buy anything but a case of mountain dew or Dr Pepper and sit back and relax!!!!!!
But until then, you will spend more and more on distributar parts vacuum line and canisters and plug and unplug every vacuum port on the engine and carb until you strech the timing chain 10 degrees negetive and have to start over.
But heck I haven't had to raise the hood of mine for weeks now, but some call it exsercise
Old 08-07-2007, 09:45 PM
vettenoir
vettenoir's Avatar
I'm running that cam in my 383. I'm very happy with the sound. A bit of a lope, but it doesn't sound like a full out race car either. Pretty good performance for a hydraulic flat tappet without crazy lift or duration. (See my signature...)
Bob
Old 08-08-2007, 12:02 AM
73, Dark Blue 454
73, Dark Blue 454's Avatar
I'll dissent. I think the XE line is poorly designed. First, with good heads and good exhaust, dual pattern will cost you ponies. Here's some good reading:
http://www.camaros.net/forums/showth...hlight=cabbage
Secondly, many XE cams fail on start up. The ramps are too aggressive for a flat tap cam. And many of those that do survive start up, report too much noise (noise = friction,..slapping valves, etc). Go to www.chevelles.com and www.camaros.net and do a search, "noisy XE cam". You'll get a 156 hits on the Chevelles page and 115 on the Camaros page...(what would we do without the internet?...believe the marketing hype?)
I would stick to the 270H or up to a 280H. Or better yet, go roller.
Lastly, how a cam would sound should be a distant concern for the street or heck at the track. It would be easy to pick a great "sounding" idling cam that ran very poorly when things got serious.
Old 08-08-2007, 01:00 AM
Little Mouse
I would like to know why more people seem to flock to comp cams ??
Old 08-08-2007, 06:47 AM
Edzred72
Edzred72's Avatar
Yeah...me too. Me thinks it's advertising & sponsorship. Their name is splashed all over the racing/high-performance industry.
For my 406 build....I choose POWER BY CROWER.
Eddie
To Comp Cams- CS EX274H-10 extreme series.
Old 08-08-2007, 08:21 PM
Tim H
Tim H's Avatar
They have a good web site that puts the cam numbers big in your face , unlike Crane.
And yes sound is important, if not then I would stick with factory and run 150 shot of NOs.
Old 08-10-2007, 02:35 PM
gmans71
gmans71's Avatar
what about the new comp cams thumper hyd roller cams they sound killer!!!
Old 08-10-2007, 04:16 PM
Little Mouse
Here is a cam I looked at on cranes web site, just one I looked at
random, no reason for picking it.
Part #110591
grind# H-22813200-25-6
1957 to 1987, chevy
262-400 cu
description
performance usage, good mid range torque and HP,
bracket racing, street, heavy, ect., auto trans
W/3000 converter, 10.0 to 11.5 compression ratio
advised, basic RPM 2800-6200
valve settings, hot, intake .000
exhaust .000
lift at the cam lobe, intake 3200
exhaust 3294
valve lift intake 480
exhaust 494
rocker arm ratio 1.50
LSA 106
cam timing at .040 tappit
opens, intake 36 BTDC
exhaust 71 BBDC
closes, intake 68 ABDC
exhaust 39 ATDC
advertised duration, intake 284
exhaust 290
Cam Timing at .050 tappit
opens, intake, 12 BTDC
Exhaust, 47 BBDc
closes, intake, 36 ABDC
exhaust, 7 ATDC
Duration intake .050 228
exhaust .050 234
recomended RPM range, with matching components
2800
6400
7000 valve float
Spring requirements
part # 96802
closed 107 lbs at 1.800 or 1 13/16 height
open 289 lbs at 1.330
All this is at one place for this cam on cranes web site. Crane has the
opening and closing for you at both .040 tappit and .050 tappit, now if the
other cam companies have more info, my hats off to them, buy there cam.
Quick Reply: Comp Cams- CS EX274H-10 extreme series.
