Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-04-2007, 08:51 AM   #1
Block_Head
CF Senior Member
Block_Head's Avatar
Default vortec head and summit cam swap
Hi guys I have been trying to locate a thread a while back where a guy was looking to up the flow and power of his engine by swapping on a set of vortec heads and a cheap summit cam. I know he also said he needed a special vortec edelbrock intake.
I started looking around and found vortec heads off of everything from cars to trucks to suvs and was just wondering what the best year and model wold be to look for and what to watch out for.
Does anyone know off hand what cam that was that was suggested?
The bottom end was rebuilt a few years back and the compression is still good and the oil pressure is high. I want to eventually do an LS swap but can't really afford it now. I figure I can do this vortec head and summit cam and intake swap and get more performance until I can afford a new engine.
Thanks guys, sorry for the long post and poor searching skills.
Block_Head is offline   Reply With Quote
Old 08-04-2007, 09:22 AM   #2
L88Plus
CF Senior Member
'96 to 2000 light trucks, suburbans and tahoes. There will only be 8 intake bolts, 2 front and 2 back on each side and they thread in straight down rather than angled toward the head. The only 2 casting numbers Chevy ever used on 350 vortec heads ended in -062 and -906. Once you get those, you'll be on your way!
L88Plus is offline   Reply With Quote
Old 08-04-2007, 12:09 PM   #3
supercalvin
CF Senior Member
supercalvin's Avatar
Tag for myself and bump for you
supercalvin is offline   Reply With Quote
Old 08-04-2007, 01:06 PM   #4
hosspowerinc
CF Senior Member
hosspowerinc's Avatar
This is for a 400.
http://www.chevyhiperformance.com/te..._block_torque/
hosspowerinc is offline   Reply With Quote
Old 08-05-2007, 09:43 AM   #5
Block_Head
CF Senior Member
Block_Head's Avatar
Thanks guys I think I found what I need.
Old 08-06-2007, 09:50 AM   #6
worship79
CF Senior Member
Support Corvetteforum!
worship79's Avatar
Worship79
Send a message via MSN to worship79
Check the 'Goodwrench quest' bij Chevyhighperformance. All the vortech information you need. Good luck
worship79 is offline   Reply With Quote
Old 08-06-2007, 05:54 PM   #7
rcastor426
CF Senior Member
rcastor426's Avatar
Send a message via AIM to rcastor426
i put vortec heads and the summit 1103 cam on a 350, motor ran real well. the cam does not need a stall converter, but def performs better with a 2000 stall. there is a post in here where someone did this as well with a dyno sheet. i belive it was 275 hp at the wheels. 315ftlbs of tq. but that is just going from memory.
rcastor426 is offline   Reply With Quote
Old 08-06-2007, 07:26 PM   #8
Durango_Boy
CF Senior Member
Durango_Boy's Avatar
Send a message via AIM to Durango_Boy
Quote:
That's not bad at all. That'd be around or over 300 at the flywheel and that's probably double that of a stock L48 right?
Durango_Boy is offline   Reply With Quote
Old 08-06-2007, 10:34 PM   #9
ajrothm
CF Senior Member
ajrothm's Avatar
Quote:
Hell, through an automatic, 275rwhp is around 350 crank HP. That will get you LOW LOW 13s, probably high 12s with a good converter.
ajrothm is offline   Reply With Quote
Old 08-07-2007, 07:54 AM   #10
Block_Head
CF Senior Member
Block_Head's Avatar
Quote:
That's good to hear. I think I like the idea of this combo and it's just what I'm looking for.
I love this forum. Just a few days and many great posts and I have a complete parts list to do this swap for under $500 and that's with new timing and even some solid motor mounts.
Reload this Page vortec head and summit cam swap
Tags
1103, 350, c3, cam, chevy, corvette, dyno, good, goodwrench, head, results, sbc, summit, swap, vortec
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
