What type of grease should I put on my sway bar bushings?
I removed the rubber sway bar bushings from my '79 to do some detailing. I am thinking I should put some type of grease or lube in the area they make contact with the sway bar, but am not sure what I should use. Any suggestions?
The only thing (if anything) you should use on the stock RUBBER bushings is "Rubber Lube". Greases (petroleum products in general) will attack and break down the rubber.
My poly bushings squeeked badly till I wrapped the bar with teflon plumbers tape.
From what I understand,a rubber bushing shouldn't even move. The elastic property of the rubber is what allows the flexing to happen. On the other hand,a poly bushing doesn't flex,and acts more like a bearing.
Premium Supporting Vendor
Note that this grease does have a good resistance to water washout and passes the rust test.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
