CFI 82 Wiring Diagram & Code chart
Re: CFI 82 Wiring Diagram & Code chart (Ganey)
I can give you a wiring diagram and maybe come up with some locations too. I can fax these or mail them to you. They don't scan to easy but will do that if you'd like as well.
Re: CFI 82 Wiring Diagram & Code chart (weendoggy)
Sounds good. Expect you are saying size is a problem for scanning, overlaping scans would work fine.
Anything on fuses amps, location & a code chart?
1 Post
Cruise-In III Veteran
Ganey, I think they're both (fuse chart and wiring diagrams) under http://www.crossfire.webhop.net - let me know if they're not.
Ken
Ken
Re: CFI 82 Wiring Diagram & Code chart (Ken73)
Ganey, try this web site: http://www.carfiche.com/ It can be a pain to navigate if you have a slow modem, but I've managed to find some good stuff online there before. Start on the index page and then it's just amatter of navigating the grid. ~Juliet
Ken
You guys did a good job on that. The 82 wiring diagram is good. The 84 wiring diagram does not come up. You need a Code chart. I have a GM one that I can scan & send if you want it.
Re: CFI 82 Wiring Diagram & Code chart (82 Super Vette)
Well, everything should be in the page Ken mentioned:
fusebox: http://www.crossfire.homeip.net:81/faq/fusebox.gif
CCCC system: http://www.crossfire.homeip.net:81/twinnie/Image1.jpg http://www.crossfire.homeip.net:81/twinnie/Image2.jpg http://www.crossfire.homeip.net:81/twinnie/Image3.jpg http://www.crossfire.homeip.net:81/twinnie/Image4.jpg
84 wiring: http://www.crossfire.homeip.net:81/tech/84Vette1.gif http://www.crossfire.homeip.net:81/tech/84Vette2.gif http://www.crossfire.homeip.net:81/tech/84Vette3.gif http://www.crossfire.homeip.net:81/tech/84Vette4.gif
There was a small bug in the code...fixed now!
We have a code chart too:!!! http://www.crossfire.webhop.net/test.html (the name of the HTML file sucks..i know :D )
Marck
[Modified by Twinnie, 7:10 AM 11/5/2001]
[Modified by Twinnie, 7:15 AM 11/5/2001]
Marck
