Can't get in my 79!
Can't get in my 79!
I'm new to the forum and need some help. My power locks are stuck. When I turn the key on either side it sounds like they are trying to open but no cigar. The windows are all the way up making it so AAA couldn't get in. The T-tops are basically stuck on since they have not been off for years. The locksmith I talked to said forcing the T's might be the only way. Am I gonna be looking for a replacement window, or do I have other alternatives?
PM me your email address please. I have something to send you that may help you out.
Ohh, what are you sending him that will help out, inquiring minds want to know! A hammer?
If nobody gives you a better suggestion, I would guess your least expensive alternative way to get in would be to break a window. Definitely don't try to pry the tops off.
If the power locks are holding it maybe you can get under the car and disconnect the negative battery cable from the frame and then try to unlock the door???
Just a thought!!
Just a thought!!
Breaking into C3s throught the T-Tops is a piece of cake with no damage to the tops. Make a fist with both hands, hit the top in the front corner over the latch. The impact should unlatch it. Thats why they sell T-top locks.
Man you should NOT be telling everyone and their mother. Sure I trust most of these guys too, but not everyone reading is a member and may not have benevolent intentions.
Not getting on your case...just saying that someone reading this may use that info to pick up a Vette...cheap.
Sorry DB but I tend to disagree, anyone who is out prowling already knows this trick. If you are a C3 owner and do not know this, then you should. Simple reason is to help protect yourself from prowlers. Granted it won't prevent a broken window, and if someone wants your car they'll get it regardless of what alarm you install. After all, this has been well known for over 30+ years but some of you guys aren't even that old yet. I had a GM dealer show me trick this after I had a new set of mirrored tops stolen off a '78. Needless to say, I bought some locks.
This will almost always break the glass top-especially the blue laminated ones.I made a video of a much safer way to get in using an oil dipstick.If you would like I can PM it to you.
Little Story
I had a female customer unlock the door on her 78 in a parking garage and get in and sit down close the door and she noticed the door lock button slowly lock.She thought that was strange but didnt give it much thought because she was going to lock herself in anyway.She went to start the car and it turned very slow but would not start.She tried again but still wouldnt start and now was scared a little being in an underground parking garage.She looked around and decided to go back to work and call her husband she hit the lock button but it didnt do anything.She then tried to unlock manually with the button but the actuator was fighting her.Her husband had put the little anti-theft buttons on and she couldnt get a grip on it.At this point she is crying and starting to panic.She tried the power window but by this time the battery didnt have enough to make it work.Now she is crying really hard and banging on the window and feeling like a she is going to suffocate.Some guys come over to the car and she is not sure if they are going to help her or rob her.After they get her settled a little they ask her to release the T-Top and she does but because of leaks her husband had siliconed the tops on.Once again she flips out and starts sobbing and they decide they better call the police.The cop comes and breaks the pass. door glass and reaches inside to pull the door handle but hits the door lock button instead and both locks open.She bails out of the car soaking wet from sweat and actually almost passes out.Car was towed to me.The pass. lock switch had stuck partially down and had almost run the battery down.That switch wasnt used much but that day she had to get something out of the pass side and had locked both doors with the pass. switch.She had me remove the power door locks and she bought a glass hammer to keep in the car.True Story
I have never heard of that way, I know on mine that the t-top latches are very firm and if I were to smack it hard enough to unlatch them the glass roof would break before the latch's released. I have heard of striking the door around the lock with the heel of your hand while jiggling the key to unlock, that works sometimes,,,Peace, Moosie
