hood insulation
hood insulation
I have a 68 and it does not have the under hood insulation blanket. Also there are not any type of clips to secure any insulation at all. I know that maybe someone (previous owner) might have installed a new hood and did not put it on.
Did this year come with or without the insulation??????? Appreciate all feed back.
Received 1,837 Likes
As far as I know, '69 was the first year for a hood insulator. Pins were glued to the hood & the insulator was held on by retainers that went on the pins. I would think a '69 should work................
Account disabled by user request 5 Jan 09
"In 1969, a piece of dark gray/black insulation padding fixed to the front underside of the hood above the radiator and front of the engine was used sporadically until late in production when it disappeared. There is no pattern for this use, but it seems to have been more common on 427 cars. Except for L88 and ZL1 cars, which had it glued in place, the insulation was held by 3 natural aluminum split shaft pins and large black metal push-on retainers"
