Edelbrock carb help
Edelbrock carb help
I have a problem with my carb stumbling at part throttle from a stop.Changed metering rods to get of popping in the exhaust from a lean condition.It worked and cars runs good.But iI still have a problem with normal acceleration from a stop.Lars said I still need to go richer be he is not familiar with edelbrocks.Does anyone have experience with these and can tell me if I need to change step up springs,jets or whatever.Edelbrock has a chart for each carb, but I am not sure what to change.
What model carb?What size engine?Do you have the owners manual?It has a chart and tells you what rods to use to richen or lean out the carb.Is the choke staying on?Does the accelerator pump work?
This is the most extensive write up I've ever seen on the Edelbrock (Carter AFB) carbs.
http://www.telusplanet.net/public/gi...delbrock_1.htm
But, I'll gather up the grey matter, stuff it back in my skull, and give it another pass
Thanks for the info
