Crate Engines, where can I find one and how expensive is it to swap?
I have been urged to consider a bigger engine for my next purchase. Were could I find a good selection of engines. Once I find it, how much does it usually cost to swap it out. I don't have the time, tools, or expertise to do it alone. :confused:
What are the drawbacks to the big engines? How is driveability, real world use (91 octane pump gas) servicing, etc.
On a related topic, how much power can the existing drivetrain handle (427 or 454 BB C3). If that needs to be upgraded, what sort of expense is that?
Re: Crate Engines, where can I find one and how expensive is it to swap? (stickanddice)
Biggest factor in octane needed is compresion ratio and ignition timing...
Hers a few vendors, these are the best Ive found and these two have all kinds of advice and support,,It appears crate motors are BIG business these days to GM. Its not hard to figgure out Why, with all us runnin around loose in the world..ha
http://www.sallee-chevrolet.com/start.html
http://www.paceparts.com/
Hope this helps..
Tom
[Modified by 69classchass, 1:22 PM 10/24/2001]
[Modified by 69classchass, 1:24 PM 10/24/2001]
[Modified by 69classchass, 1:26 PM 10/24/2001]
[Modified by 69classchass, 1:29 PM 10/24/2001]
Hope this helps..
Tom
http://www.sdpc2000.com/default.htm
Most of these crate engines run on regular gas. They come with a warranty. Most shops will probably treat an engine swap like a human heart transplant and charge you accordingly! :) although the guys that have done it say it's not all that tough. MJ
Platinum Supporting Dealership
Re: Crate Engines, where can I find one and how expensive is it to swap? (Alwyn678)
I am thinking of buying this: http://www.sdpc2000.com/cart.asp?act...id=514&pid=622
Putting my comp cam 268H, edelbrock performer, roller rockers stock q-jet (all on current motor) and either AFR heads or Trick flows with headers on this. I would rebuild my 700r4 at the same time and put that in.
What do you guys think?
Quote: "I have been urged to consider a bigger engine for my next purchase. Were could I find a good selection of engines. Once I find it, how much does it usually cost to swap it out. I don't have the time, tools, or expertise to do it alone.
On a related topic, how much power can the existing drivetrain handle (427 or 454 BB C3). If that needs to be upgraded, what sort of expense is that?"
According to your Profile, you have a 1998 corvette, don't believe I'd be trying to fiit a BB in a C-5, question whether you're for real.
Re: Crate Engines, where can I find one and how expensive is it to swap? (john's '81 mouse)
If you read all my other posts you'll find I'm inquiring pretty heavily about a C3. I plan on selling my C5 and getting a C3. I'm going to be posting some pics of some of the problem areas I've found in the Restoration Section (Bubbling paint). Once I sort out what I want exactly I'll go ahead and either purchase the C3 or keep the C5. So far, if the price is right, I'm thinking of looking for a LS 5, due to the driveability factor (Post: 427 or 454).
Just because I have a C5 does not mean that I shouldn't be curious about other vettes. Especially when I'm shopping around. Everyone I've spoken to has told me that asking "Corvette People" is the best way to get acquainted with an older classic prior to plunking down the cash.
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
U need to contact BSEERY on the forum....bryan is currently doing this :smash:
Check out my ZZ4 motor swap at http://temp.corvetteforum.net/c3/bseery/zz41.htm.
Price -- if you keep the stock carb that will save you $500. If you do the swap yourself that should save another $1000.
Motor, flywheel, and waterpump cost me $3700 w/ shipping.
Damn nice motor.
Re: Crate Engines, where can I find one and how expensive is it to swap? (69classchass)
As far as I can tell, all the GMPP dealers have the same price.
Sallee Chev in Southern Oregon will be closest and have the lowest shipping and no sales tax for you.
Big blocks are expensive to swap in and transfer over in a small block car.
Smog kicked in, in 74 and big blocks were last offered in that year, so you can't change much post 74 cars.
Evan
Evan
Re: Crate Engines, where can I find one and how expensive is it to swap? (Rhys)
Rhys,
Wow, a short block for less than $1900! I'm jealous. I'm looking into a short block for my big block, and they START at $4000!
-Joe
[Modified by Flareside, 9:17 AM 10/25/2001]
-Joe
Re: Crate Engines, where can I find one and how expensive is it to swap? (Flareside)
Rhys,
-Joe
-Joe
Re: Crate Engines, where can I find one and how expensive is it to swap? (BSeery)
Bseery,
Who did you get your ZZ4 from? hot cam? how much hp? If I can get mine for $3500 range, I will do that instead.
Rhys: I've seen the ZZ4's (355HP version) for anywhere from $3,300 - $3,500. Pace has them for $3,395. The 385HP Fast burn version is $3,999 at Pace, but I've seen them for $3,850. With the addition of a HOT cam and 1.6 roller rockers, the 385 fast burn is supposed to make 430HP (It's basically the ZZ430), but I'm thinking that's something you could do yourself before you drop it in. You wouldn't have to pay Pace to do it.
These prices might be less if you use your stock carb.
[Modified by 79MakoL82, 9:03 AM 10/25/2001]
Re: Crate Engines, where can I find one and how expensive is it to swap? (79MakoL82)
I'd really like to accomplish 400hp with $3500 or so. Maybe it can't be done. I am going to check my noisy rod bearing this weekend and see if thta is the problem. If it is not an "easy" fix, I am going with a crate motor.
I think your ZZ4 short block with AFR heads idea should get you about there. The recent CHP rated the AFR 190's as the best flowing heads that they've tested. I'm not sure, but at the most, you might need to go to a little more cam, but the rest of the set up sounds good to me. An RPM air gap would help, but then you couldn't use your quadrabog and you'd have hood clearance issues so there's extra $$$. The ZZ4 shortblock is a great platform to build on and would definately consider that as a good starting point.
CI 6-7-8 Veteran
Mine was from Sallee Chevrolet for $3295 + shipping (if my memory is right)
I talked to Tom there -- the phone number and info is on my ZZ4 swap page at http://temp.corvetteforum.net/c3/bseery/zz41.htm - it has the prices, the need to have parts, the contact name and everything.
Good luck -- it's a fun motor.
I didn't notice the other replies dealing with this part of your post, so I'll take a shot at it.
When I did the crate swap into my '81, I ended up spending about $1500 beyond the cost of the engine and shipping, and I did the actual swap myself (with the help of a friend). The engine was a long block assembly plus sheetmetal, so I still had to get a manifold. I also added roller-tipped rockers, new fuel pump, new clutch, and new ignition parts. Most of the $1500 went into a long list of relatively small parts and pieces, like new hoses, belts, fasteners, gaskets, etc., plus a significant amount of machine shop charges for things like bead-blasting the exhaust manifolds, resurfacing and balancing the flywheel, etc. And there's the rental charges for the engine hoist, engine stand, and a few special tools that I didn't own.
I could only guess what you would have to pay someone to do the work for you. I did most of it in about 2 days, so maybe $500 for labor ??
Good luck with it! :seeya
Re: Crate Engines, where can I find one and how expensive is it to swap? (Gator81)
I just did a motor swap at the biginning of summer. I didn't have that much experience so I had a friend help me out. I went with a 383 stroker.
http://www.speedomotive.com/chevy_383_street.htm
The engine came complete from intake manifold to oil pan. I did upgrade to an air gap manifold. The complete engine ready to install was delivered to the local shipping company in my town for $3800 of wich you get back 150 when you return the crate. I had to also buy a new clutch, Distributor and a whole lot of nick-naks. It cost me at least another $1,200 to compete the job without the new hood to fit the intake under. It took me about 2 weeks of working several hours here and there on it.
The end result was a 13.2@107 mph with no launch at all on 3.08 gears. It is spectacular. I did have to chain the engine down as it broke my brand new motor mounts in about 5 min after we had it running. Havn't got around to ordering solid mounts yet.
Suprdave
Suprdave
