Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2007, 11:10 PM   #1
Mike's 68
CF Senior Member
Mike's 68's Avatar
Default Solid Lifters (LT-1) or Hydraulic?
When I went to adjust my valve lifters last weekend I discovered that they were adjusted as if they were hydraulic (no gap). Now I'm confused, all the information I have on my engine says it should be a '70 Z-28 LT-1 engine with solid lifters. Here are the numbers off of my engine and their meaning (as best as I’ve been able to determine):
Engine Assembly Date/Suffix Code: V0528CTB - 28 May 1970 Camaro Z28-LT1 350/360HP 4 bolt main
Block Casing Number: 3970010 - 350 cubic inches
Block Casing Date: E270 - 27 May 1970
Intake Manifold: 3972116 - Service Replacement for 3972110 (70 Camaro Z28)
Head Casing Number: 3927186 - 2.02 intake, 1.60 exhaust, 63.305 cc, screw in studs & guide plates
Head Casing Dates: 29 Jan 1970 Passenger side
6 Mar 1970 Driver side
So did Buba adjust my lifters or does this engine have hydraulic lifters instead of the solids lifters I thought.
Mike's 68 is offline   Reply With Quote
Old 06-01-2007, 11:18 PM   #2
big_G
CF Senior Member
big_G's Avatar
Can you be absolutely sure the engine has not been gone into before? Maybe someone changed out the solid cam for a lower maintenance hydraulic piece.
big_G is offline   Reply With Quote
Old 06-01-2007, 11:36 PM   #3
Mike's 68
CF Senior Member
Mike's 68's Avatar
Quote:
That's what I'm afraid of, I guess the only way to tell is to tear the engine apart? I did re-adjust the lifters as if they were solid lifters and everything seems alright (not noisy). The engine does look like it was re-built not too long ago, the heads were as clean as a whistle. I would hope someone wouldn't change out the solid lifters on a LT-1 engine, but who knows maybe they hated adjusting valves.
So now I don't know what my redline should be .
Old 06-02-2007, 08:50 AM   #4
Jughead
Senior Member since 1492
St. Jude Donor '09
Support Corvetteforum!
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell. 3. Islam is the enemy.
Send a message via AIM to Jughead
Even with the correct valve lash (adjusted) my solid lifters still make the distinctive clackety-clack noise unique to solid lifters.
You can hear the noise here......http://home.comcast.net/~eddiengerry/BB_startup.mpg
__________________
1970 454- M-22 W/Hurst Comp+ 4 speed, Sidepipes, Mellings, Clevite 77, GMPP Al heads, Manley, Moroso, NO cup holders &
Not Correctly Restored Stingray................
When "Cool" was Measured in Cubic Inches!~Nuthin' Like the Sound of a Solid Lifter BB.
Jughead is offline   Reply With Quote
Old 06-02-2007, 10:00 AM   #5
stingr69
CF Senior Member
stingr69's Avatar
One thing you can check is to lean down hard on a few of the rocker arms that are over closed valves. You should be able to feel a little "give" from a hydraulic lifter where a solid will not "give" at all.
All lifters will make noise when adjusted as a solid, even the hydraulic ones.
After that you could go find a dial indicator and verify the cam lobe lift. This is pretty easy and can put your mind at ease as long as it turns out to be an LT-1 spec cam in there. If it is not, then you will need to dig deeper for more evidence of what was put in there.
-Mark.
stingr69 is offline   Reply With Quote
Old 06-02-2007, 10:03 AM   #6
Mike's 68
CF Senior Member
Mike's 68's Avatar
That helps! I definitely have the clackety-clack noise but it is not as easy to hear as yours, but if I stick my head into the engine compartment it is there. From inside the car and off to the side I hear alot of noise from the fan (air flow, seems like huricane force winds), do you have an electric fan? I'll try again when the engine is hot (after some yard work, I'm setting the timing per forum instructions).
Old 06-02-2007, 02:23 PM   #7
Mike's 68
CF Senior Member
Mike's 68's Avatar
-Mark.
Things are looking better, I just re-adjusted the lash (all were very close since I did it last weekend) and did the lean test, no give. I tried it a number of rockers while trying to slide in the next size up feeler guage (.001 larger), none gave .
Old 06-02-2007, 02:39 PM   #8
Matt Gruber
CF Senior Member
turn 1 valve 1 turn past 0
it will run like crap w/solids
will smooth out if H
__________________
A/F O2 tuning experience since '98.
ASE Certified 1984 in ENGINE PERFORMANCE, Engine Repair, and Electrical Systems...
http://community-2.webtv.net/MATTGRU/carb
Read how my cruising mpg went from 11 to 19 mpg! (4 hole isolator gasket) increased mpg & torque- all from a simple gasket!
Read why LS1's get great mpg. Way more than just EFI http://community-2.webtv.net/mattgru/EFIMPG
Newest mod- TVS Trapped Vacuum Spark-Drives off cold with no choke and no warmup.
Matt Gruber is offline   Reply With Quote
Old 06-02-2007, 07:41 PM   #9
WESCH
CF Senior Member
WESCH's Avatar
Hi
The hydraulic has a snap ring on top in the outer edge of the cup
The solids do as well. Very difficult to see a difference. Also the solids have this snap ring and have like washers installed , probably because of it's oil passage through them and up to through the pushrods.
My 68 , when I bought it, had a solid lifter cam with hydraulic lifters installed. The previous owner renewed the engine and thought to buy new lifters because they where noisy.
I found out when checking engine numbers , that it had L71 heads, then checked the old original lifters which he gave along in a oily plastic bag to find solid lifters. They look alike the hydaulic lifters.
I am not sure if you can feel solid lifters by pushing on the rocker by a no give. Good hydraulic lifters don't give. If your a specialist, you might feel the initial difference, but they don't give.
I would think that hysraulic lifters , when adjusted like solids with a gap, are much less noisy as solid lifters due to this slight give that could dampen the initial touch clonk, but who knows how to hear this wihtout comparison.
I guess you will only be sure once you checked the cams numbers and took a lifter out and dimantel it.
By the way. You can install hydraulic lifters onto a solid cam , but wiseversa doesn't work. Solid cams are softer to eliminate lifter knock. Hydraulic cams don't need this because of the slight give of hydraulic lifters that dampens the knock.
Günther
WESCH is offline   Reply With Quote
Old 06-03-2007, 09:45 AM   #10
Ed Blue 03
CF Senior Member
Ed Blue 03's Avatar
Quote:
it will run like crap w/solids will smooth out if H
Just installed a 70-LT1 cam and lifters, the lifters do have snap rings and look just like hydraulic lifters. Think the above test is the easiest way to determine what you have. Good luck.
Ed Blue 03 is offline   Reply With Quote
Old 06-03-2007, 10:13 AM   #11
S489
CF Senior Member
S489's Avatar
Default just some rambling thoughts . . .
if there is a chance that the engine has been gone through, i'd assume that the pistons and cam were changed to a lower CR and hyd cam. at one time, when a lot of engines were needing to be freshened up, and ethyl was going the way of the dodo bird, it was common to drop the CR and use an aftermarket (as opposed to GM) cam. many went with hyd, i think because at the time hyd grinds had improved and would perform as well under normal driving with better mpg, also having the advantage of not having to fiddle with solid lifter adjustments. the adjustment effort was more perception, and a lot of owners wanted to drive then, and not work on them at the time, i think.
Bottom Line: If it were mine, i would readjust the way they were (like they were hyd)(damage could eventually result from running hyd with zero or more lash).
then, try to confirm from previous owner what is in there if possible. at some point, you may have to dissassemble to see cam number. however, you may be able to map the lift vs crank/cam degree using travel indicator, etc., to get a profile close enough for a cam mfg to tell you if it is solid or hyd. maybe give your favorite mfg a call to see how they recommend you can most easily accomplish this; any tips, etc.
for whatever it's worth . . . hope this helps
S489 is offline   Reply With Quote
Old 06-03-2007, 04:40 PM   #12
Mike's 68
CF Senior Member
Mike's 68's Avatar
Thanks for all the suggestions. I'm going to set the lifters as if they are hydraulic and see how that goes. When I adjusted the lifters the first time I backed off the rockers by 3/4 to 7/8 of a turn to get the solid lifter's lash (E=.026 and I=.21 cold and 90 degrees off of TDC). This time I do one full turn after zero lash and see what happens.
Next winter I'll try to muster up the nerve to pull the cam and see what it is.
Reload this Page Solid Lifters (LT-1) or Hydraulic?
Tags
1970, 3970010, cam, clearance, e270, engine, hydralic, hydraulic, installation, lifter, lifters, ls1, lt1, solid, solidvshydraulic, sound, z28
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Name That Cam - Our Next Contestant is.. stingry C3 Tech/Performance 17 05-03-2005 03:49 PM
LT-1 Cam and Hydraulic Lifters - Again Dave McDufford C1 & C2 Corvettes 20 11-17-2003 06:23 PM
Rebuilding a '66 327/350hp would you do roller rockers? sams'66 C1 & C2 Corvettes 13 09-12-2003 12:07 AM
Lifters, Hydraulic or solid? Billy Boguski C1 & C2 Corvettes 14 10-11-2002 04:21 PM
Is it a fake? 427basketcase C3 Tech/Performance 12 09-30-2002 08:21 PM
HYDRAULIC LIFTERS VERSUS SOLID LIFTERS? tuxedo C1 & C2 Corvettes 26 12-16-2001 02:21 PM
Lifters clicking. made adjustments, now backfiring. taekwondo-kicker C3 Tech/Performance 12 08-08-2001 09:32 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
