Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-23-2007, 02:59 PM   #1
GD70
CF Senior Member
GD70's Avatar
Default AC Delco plugs vs. Autolite vs. ??
Any major difference between these or Champion plugs? Engine has about 10-11k miles on it. Current plugs have been for a while have outer surface rust and were in when I got the vette this past December.
Also have pinging using 93 octane, fiddled with the timing but still have it under load, but will do a full tuneup. What about seafoam or water or Chevron Techron to get rid of possible carbon build up. Just put some right down the carb while runnung? I heard will smoke like hell for about 5 min. Can carbon buildup occur in this amount of milage?
Thanks in advance.
Glenn
GD70 is offline   Reply With Quote
Old 05-23-2007, 04:44 PM   #2
Gunn353
CF Senior Member
Gunn353's Avatar
Autolite I have found are junk, I have been recommended ACdelco...Champion arent that great. I would use Accel or my personal favorite NGK R plugs. Others may have further insight though.
Gunn353 is offline   Reply With Quote
Old 05-23-2007, 04:48 PM   #3
Roughrider
CF Senior Member
Roughrider's Avatar
Send a message via MSN to Roughrider Send a message via Yahoo to Roughrider
Spark plugs is one of those issues that you'll find little agreement on. Everyone has a different favorite. A friend who used to race Chevies preferred Champion in small blocks and AC plugs in big blocks. I've gotten mucho advice to stick with AC plugs. A speed shop I deal with only installs NGK.
My own experience has shown me whatever application a manufacturer specifies should work fine. Years ago I worked for JC Penney in one of their auto centers (long gone now). We sold Champion, Accel and the house brand JC Penney spark plugs (made for them by Prestolite). I tried them all and found no difference as long as the heat range was right.
You don't need one of those big dollar spark plugs...platinum tips, funny electrodes, etc., unless your specific car calls for it. I tried Splitfire plugs in one car I owned...within a short time two of them cracked their ceramic insulators from the engine heat. They were a waste of money so I went back to oe plugs and had no more problems.
I know others will have their pet spark plug brand and that's fine. I'm just saying use whatever manufacturer's correct application and heat range and you should be fine.
Roughrider is offline   Reply With Quote
Old 05-23-2007, 04:57 PM   #4
stingr69
CF Senior Member
stingr69's Avatar
Autolite have a wider heat range and foul less than the AC Delco plugs I have used. NGK are good too but I prefer to buy Autolite because they have solved fouling problems for me in the past.
-Mark.
stingr69 is offline   Reply With Quote
Old 05-23-2007, 05:02 PM   #5
GD70
CF Senior Member
GD70's Avatar
The R44's are a hotter plug I believe. Will this help with ping? Still curious re: carbon & ping relationship and a cure.
Glenn
Old 05-23-2007, 05:05 PM   #6
Tim H
CF Senior Member
Tim H's Avatar
I had a 79 Z28 that would miss on everything buy Autolites.
Now this vette I have had Autolites and missed like crazy so I changed to R45ts AC and it purrs like a kitten.
I like AC but for a higher price I bet NGK are good also.
As for the detination, there must be a hot spot on the piston, I would tricke water down the carb but not to kill it while doing it,chances are , bad gas.
To spend a little money you could get a hotter coil and gap your plugs to .050 for a wider spark to take advantage of the better coil.
Also try heavier springs on your weights in the distributar to see if you can lose the detintion at lower pulling speeds.
Tim H is offline   Reply With Quote
Old 05-23-2007, 05:07 PM   #7
GD70
CF Senior Member
GD70's Avatar
Thanks for the advice!
Old 05-23-2007, 07:18 PM   #8
chuck d
CF Senior Member
chuck d's Avatar
It is simple. AC Delco's in Chevy's, Autolites in Fords. NGK's or Nipondenso's in cars from Japan.
__________________
chuck d
73 coupe
M20/3:36
4 bolt main/forged pistons
Comp Cam valve train/268H,lifters,push rods,springs,roller rockers
LT1 intake/holley 600/LT1 open element aircleaner
Alumicoat headers/chambered exhaust
Comp TA tires 255-60x15 / Grey powder coated center 15x8 TT II's
1 1/8" front bar/ 7/16" rear bar
chuck d is offline   Reply With Quote
Old 05-23-2007, 07:52 PM   #9
Gunn353
CF Senior Member
Gunn353's Avatar
Quote:
Wait, maybe it's my honda 250R i run NGK's in...
Old 05-23-2007, 08:43 PM   #10
Tim H
CF Senior Member
Tim H's Avatar
Is it Champions in Dodge???
Old 05-23-2007, 08:54 PM   #11
merlin5353
CF Senior Member
St. Jude Donor '07-'08-'09-'10
Support Corvetteforum!
merlin5353's Avatar
__________________
'71 Ontario Orange Coupe, stock SB 4-speed
'04 Torch Red Vert, Black int., Auto
Also, '64 Caddie & '69 Pontiac Vert.
merlin5353 is offline   Reply With Quote
Old 05-23-2007, 10:16 PM   #12
Kalway
CF Senior Member
Kalway's Avatar
Send a message via AIM to Kalway Send a message via MSN to Kalway Send a message via Yahoo to Kalway
I've run mostly autolites for the last year or so, never had an issue with em. Engine always starts with a quick turn of the key and never had a cylinder miss... I'm also running vortec heads now, still no problems.
Kalway is offline   Reply With Quote
Old 05-24-2007, 12:21 AM   #13
73, Dark Blue 454
CF Senior Member
Autolites for me,..the regular "copper-cores" which run about $1.25 each,..and this coming from a die-hard AC-Delco fan for any other part. For me, they perform better, last longer and have a variety of heat ranges. Here's a link,..go to "understanding spark plugs" for some good info.
http://www.autolite.com/carcare/techSpecs.php
73, Dark Blue 454 is offline   Reply With Quote
Old 05-24-2007, 01:58 AM   #14
68RATVT
CF Senior Member
68RATVT's Avatar
I run standard NGK in all my vehicles,hot rods, bikes and DD, platinum,iridium,titanium,chromium or gold plugs in the older motors carbon up and DO NOT clean off, Unless it's been rebuilt for unleaded gas and emissions.
68RATVT is offline   Reply With Quote
Old 05-24-2007, 11:41 AM   #15
GD70
CF Senior Member
GD70's Avatar
Looking for distributer springs and will try water re; carbon build up. I would assume that I know I've done it enough when the pinging stops.
Gas is Sunoco 93 octane.
The pinging started when I put a few gallons of reg a couple weeks ago. I assumed my engine is low compression 8.5 to 9.0 and would run fine on reg.
Old 05-24-2007, 12:26 PM   #16
Tim H
CF Senior Member
Tim H's Avatar
Different grades of gas comes from different tanks in the ground, the regular could have had water in it.
I would do the water thing, but don't expect miricals!
You might have to take out 4 degrees of timing, or put the heavy springs in so the advance has to wait until higher RPMs to open, this way the motor is having less demand on it.
Old 05-24-2007, 12:39 PM   #17
PETKAH
CF Senior Member
On my '70 had a ping then did a complete tune up. Still had the ping -
used GM top cleaner (About $6) lots of black smoke - no ping and now
runs like a rocket.
PETKAH is offline   Reply With Quote
Old 05-24-2007, 12:51 PM   #18
GD70
CF Senior Member
GD70's Avatar
runs like a rocket.
Gm top cleaner available at NAPA Auto Zone etc.. or from Chevy dealer? I want to get some.
Thanks, Glenn
Reload this Page AC Delco plugs vs. Autolite vs. ??
Tags
ac, acdelco, auto, autolite, champion, chevy, delco, iridium, lite, platinum, plugs, r45ts, spark, verses, vs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
