which port to use for timing
not trying to argue but 'ported vacuum' is created by the venturi.
. The vacuum source was changed from the manifold to the carburetor venturi. This is called "spark ported vacuum." Spark ported vacuum is lowest at idle, and then increases as the throttle is opened.
from this article
http://www.corvettefever.com/techart...curving_power/
from this article
yes a waste of time.
Just hook it all back up and don't fool with it or you will have the car in a million pieces and driving the SUV on cruise night!
from this article
from this article
edit-Here is an article that I found that Lars wrote that explains the different vacuums.
http://www.lbfun.com/Corvette/Tech/v..._explained.pdf
A ported vacuum source is pulled from above the primary throttle blades.
A manifold vacuum source (or full time) is pulled from below the TB's.
If you're not sure which port on the carb is which, hook a vacuum gauge to it. At idle, you'll have a very low reading with a ported source and if you've accessed a manifold source, you'll have a very high reading on the vaccum guage.
The vacuum signal goes down, not up, as you open the TB's (step on the gas). This will reduce the timing in the distributor to prevent pinging or knocking on acceleration.
As stated above, manifold vacuum is the preferred source,..you'll have better off-idle performance and a cooler running engine, especially in stop and go traffic. Also, if you suffer from dieseling, manifold vacuum will allow you to shut your TB's more. Dieseling is almost always caused by the primary TB's too far open at idle.
Hope this helps,..pretty simple system,..but often misunderstood.
Does this sound right, BarryK? Hook your advance can to manifold vacuum for best performance, unless that causes ping. If that ping can't be cured by changing cans, then go with port vacuum, which will result in less vacuum advance.
Using a dyno is the ultimate solution for setup, but to help understand this vacuum and how it affects your car you can run a gauge inside as you drive under different conditions (ported or vacuum).
I've used one inside for years and it's a valuable tool at times.
from this article
from this article
Venturi vacuum is created by air flow moving through a restriction (venturi). Even in the most sensitive carburetors the main venturis don't begin to function (produce enough vacuum signal to begin to meter fuel) until about 25 of 30 MPH. Up until this speed the engine is running on the idle and transition circuits. If you're chugging along at 1200 RPM in high gear you have ported vacuum but the main system venturis have not started up yet. There is no venturi vacuum yet. Also, in a Quadrajet carburetor venturi vacuum only does one thing, provide the power to meter fuel.
THERE IS NO VACUUM PORT FROM THE VENTURI TO THE OUTSIDE OF THE CARBURETOR! IT IS IMPOSSIBLE TO USE VENTURI VACUUM FOR ANY OTHER PURPOSE IN A QUADRAJET CARBURETOR!
Ported (timed) vacuum is created by piston displacement, not the venturi. No matter how much some of you may want it to be the venturi, it isn't!
Get a book and study up on it.
BigBlockk
Later.....
Usually pinging is from too much mechanical advance and a surging while cruising is caused by too much vacuum advance.
It works fine for me...
My 350 /290 with an Edelbrock 1806 starts, idles and runs fine with the vacuum advance line hooked up to full vacuum.
Chris B
Chris B
