73 BB heads.
73 BB heads.
Can anyone tell me how large my stock 73BB heads are.
My compression rate now is 8:25.1
And i was wondering what compression i would have if i put in 110 or 100cc aftermarket heads.
(Are looking at edelbrock RPM)
Senior Member since 1492
You can go HERE and figure it out.
I think Procrastination Racing is a member here.
If you don't know head gasket thickness & amount in hole you could use 0.049
Problem with this type of calculator is that you don't know what value to use for the piston volume. I guess you could use zero as an example and just change cylinder volume.
cyl dia = 4.251
stroke = 4
chamber = 118
piston dome = 0
gasket thickness = 0.049
Compression = 8.18.
changing to 110 cc heads = 8.66
100cc heads = 9.348
cyl dia = 4.251
stroke = 4
chamber = 118
piston dome = 0
Compression = 8.18.
100cc heads = 9.348
The stock 73 heads are the 049 castings, arguably the best large oval port head as cast for flow numbers. But they are handicapped in two ways, one the cc's on the cumbustion chambers are 119, and they run the smaller valves 2.06/1.72. If you can get the compression up a little bit and install some larger valves and due a bit of pocket porting they are great street heads.
Pat Kunz
Pat Kunz
