How can I change Muncie oil?
Old 04-17-2007, 05:47 AM
attila
attila's Avatar
Default How can I change Muncie oil?
I searched in 1972 Shop manual but I can't find how to drain (or suck) the oil from the tranny and replace it.
I just replaced rear axle oil sucking it with a giant syringe, I would do the same on Muncie but can't find the plug :-)
thanks
Old 04-17-2007, 10:04 AM
BBNJKen
BBNJKen's Avatar
As I recall from my '67 ragtop 4 speed days, a filler hole with pipe plug should be on trans passenger side, approx half way up the side.
There also should be a boss for a drain plug on the bottom of the passenger side of the trans. I had drilled and tapped the boss for a small ( 1/4 or 3/8") pipe plug, although I think I had the trans out when I did it. It might be possible to do it with the trans in the car, but I honestly do not remember.
Perhaps someone else will jump in with a more current advise.
BB NJ Ken
Old 04-17-2007, 11:24 AM
attila
attila's Avatar
thanks! I had a quick look at the wrong side, if no drain I will suck it with my big syringe
Old 04-17-2007, 02:34 PM
msalvemini
4th Gear
msalvemini's Avatar
I beleive we have the same issue. I could not suck the oil from the fill hole, hose would not go in more than an inch. If you find a method that works please share. I do not want to drill and tap.
Mike
Old 04-17-2007, 04:20 PM
attila
attila's Avatar
ok, drained the old muddy oil and put 1 1/2 qt of Amsoil synt 80w90 I had in the shelf, it should be ok at least better then almost nothing and muddy!
my vette sat for more than 2 years since I bought.
thanks!
Old 04-17-2007, 08:14 PM
427Hotrod
427Hotrod's Avatar
Received 1,873 Likes on 911 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Usually you can pull the bottom bolt on the tailhousing and it will drain out there. Not perfect.....but it will get a lot of it eventually. Needs to be warmed up..or let it sit for a week or so draining!
JIM
Old 04-18-2007, 03:31 AM
attila
attila's Avatar
yes I saw and thought about it, it's just at the rear end!
To How can I change Muncie oil?
Quick Reply: How can I change Muncie oil?
