LED Parking lights, amber/white .. is it possible?
St. Jude Donor '08
I am collecting all need LED lights needed for my whole car, now I had an idea regarding the fron parking lights, I thought it may be possible to find some LEDs that has a white color for parking and turns into amber for turn signalling, is such LED exists? I tried so many different LEDs website but I just didnt came through it.
My thought was it may be a 50/50 of amber/white small LEDs.
any inputs?
Hamad
any inputs?
Hamad
You can probably find quite if you do a search for LED. Suggest using Advanced search.
There have been many discussion threads. Here are a few links. . .
www.superbrightleds.com
http://forums.corvetteforum.com/show...1473939&page=1
http://forums.corvetteforum.com/show....php?t=1565290
http://forums.corvetteforum.com/show....php?t=1618943
Jim
Jim
St. Jude Donor '08
Hi Jim,
I've been through these websites, I cant locate what I'm looking for. What I need is a dual illumination (amber/white or yellow/white) LED bulb. for the back up it white will lid, and when I turn signal the amber or yellow color will flash. all with in the same bulb. like if a single bulb has 16 LEDs, there should be 8 white and 8 amber/yellow.
Anybody knows if they exist at all?
I have no idea if such a LED set exist. I would suggest contacting them at 314-972-6200.
http://www.superbrightleds.com/led_prods.htm
Good Luck.
Jim
Good Luck.
Jim
Hi Jim,
Dave
any inputs?
Hamad
any inputs?
Hamad
St. Jude Donor '08
Digi-Key will have what you're looking for! I found yellow/white but may have amber/white. White may also be called 'clear' but not sure. Phone: 800-344-4539
I couldnt locate that particular bulb, can you get me the Digi Key part number?
HAmad
