Dumb question regarding oil and filter...
Hey all, sorry for what's probably a very stupid question, but I'm about to restart my car from winter storage and want to know... is there any reason I need to change the oil or filter after storage of 4 to 5 months? I changed the oil and filter before storing, so both were fresh at the time. I have always changed my oil and filter before and after winter storage, but I'm just wondering if post storage is necessary.
Does anything in the oil settle or maybe change chemically during that length of time and due to the cold weather, or should I be able to just fire it up and not worry? I suppose it's possible for the oil to break down due to the Chicago cold temps and length of time that makes it important to change the oil after storage, but I want to confirm this before I bother.
Thanks in advance for your help!
Start it first before changing. Already will have several seconds before the pressure comes up in the engine; no need delaying it further by changing the oil and filter first.
Received 1,838 Likes
I never have changed my oil after winter storage unless it was due. And you should always change your oil hot. Dirt & crap sticks to the inside of your motor when it's cold but it gets back into the oil once it's hot..........
If you really can't control your urge to start it than at the very least let it come up to operating temp for about 15 minutes before shutting it down again.
not doing that will cause condensation to develop and stay in the exhaust system and will cause rusting problems.
your best bet if you aren't going to actually take the car for a nice 1/2 drive or so is to just let it sit and do not start it
