STS Turbo
#61
Cheap
I don't know of anyone on this forum who's done this, I've also been thinking about it and would have noticed. You mentioned in an earlier post that turbos are cheap, from what I've seen they're around $1300 a piece, add about $500 for the ceramic bearing versions, clearly the most expensive components, unless you're looking at Chinese units. I will investigate the possibility of using a single turbo, from what I've read they are just as affective, just not as .
Right now the biggest hurdle information wise is sizing the turbine housing to account for the heat loss incurred from the remote location, I have several books but none address this issue.
#62
The blower may cause losses at the crank but the sts kit causes losses due to it's mounting.
