took a trip now it wont idle
I drove my car (77 4spd) today for about 100 miles when I get off the expressway I put it in neutral and it drops down past the normal idle speed and seems like its going to die, I rev the engine until I got home to keep the car from quiting, when I do get home I checked everything out and it appeared to be ok, fired it up, it idled for about 10 seconds then died. The whole top end is new and I have not had this problem before, any ideas on what could be wrong?
-alex
-alex
My first thought is something may have worked it's way into the idle circuit of your carb. It may need to be cleaned. Before you take it apart, check to see if you can adjust the idle back up with the idle screw. I have seen the idle screw back out over time and cause the engine to idle too low and die. That would be an easier fix.
I pulled one of the plugs and it looked like ****, one of my buddies who works at a speed shop suggested it and also said I may want to look into getting an MSD box and how it cleared up fouled plug problems he had seen and experienced before. thanks for your input guys.
-alex
-alex
I'm not that familar with the demon carbs.But i think it has a power valve so check it ,also check your float levels.Check the air filter base see if it has gas stains .
-alex
-alex
I have hte same problem with my quad. i set my idle screw in and it only dies and stalls when i drop into gear... but it will idle in park.... I have to get a new hose for my pcv valve, it was broken so the pcv inlet on the carb was wide open... i dont know if thats the problem yet.. I also just replaced my electricle made it better but not gone... let me know what you do to fix it
Did you try adjusting the idle screw? On my new rebuild i was checking the carb to see if it was opening all the way, engine was not running, when she warmed up it wouldn"t idle i assumed linkage sliped when i held gas pedle to the floor for someone to check carb opening. I idle it up with the idle screw not another problem. That 750 may require some adjustments to stop the plugs from looking like black.
it runs a little rich at idle, as for the idle in general, I looked at the idle adjust scew and have a few other ideas of potential problems, can't really check them out now, but the whole weekend is open.
-alex
-alex
