VR1 Racing Oil isn't the oil we thought it was
#41
Location: San Diego - Deep Within The State of CONFUSION!
I never once had an engine failure.
When I purchased the stroker that's in my C3 now, I asked for a recommendation on oil, from the builder. He said the only one to use is Valvoline Racing Oil. 20w-50.
Now it's 5 hard years later, and the stroker still is together.
So I'm sticking with what works. Valvoline Racing Oil.
Noliftz06 (05-31-2021)
#43
i like the idea of well formulated oils to begin with but here is that oil additive from Comp Cama
"Engine Break-In Oil Additive Case - 12 (12oz.) Bottles
PART #159-12
$133.32 "
PART #159-12
$133.32 "
#44
All I know is one thing: in YEARS of building hot rod motors myself, I used Valvoline Racing oil. Most of those years I was hot-rodding engines I built long before I had any actual engine building skills.
#45
I've been buying VR1 from Kragen for the past few years. But that designation wasn't always there. I always just got the standard issue Valvoline Racing oil that was sold retail.
It always has been seperate from their standard 20w-50, even before they put a VR1 logo on it.
#48
Look around, there are many "race engines" now operating in nasty street cars. And while they don't see WFO operation like a track engine does, they still end up seeing enough WFO use, that Racing Oil is a benefit. Besides that, stiff valve springs don't know if they are in a street car or race car, so the valve train still needs protection. Racing Oil offers the best insurance of that.
#49
Dep
#50
Here's some more interesting reading I came across.
http://www.valvoline-technology.com/...%20Galling.pdf
Seems we all need to keep studying....from the Valvoline tests you would believe that *what's new isn't always best*.
Who'da thunk it??
JIM
Who'da thunk it??
JIM
I've been thinking all along that these roller rockers in my engine are not prone to the issues some of you folks have been having with flat tappet camshafts, looks like maybe I've been sleeping at the stick. ???
Do you think I would be wise to use Valvoline VR1 oil rather than ordinary say Quaker State, Mobil etc petoleum base oils for added protection against premature camshaft/lifter wear even with roller rockers?
Bill
#51
with roller rockers you are ok with any good brand of oil, the zinc and phosphorus is for the flat tappet cams and especially with high spring rates and steep ramps
#53
The tests in the article were done simulating roller rockers, there was a direct correlation between oils having low traction and camshaft galling. I don't see how that shouldn't be a concern if you belive the test results. Or am I missing something??
#54
the newer formulated oils were designed for the roller rockers, i see no harm in using VR1 and i use it in my vette but all my newer cars i use mobil 1.
#55
they were measuring base oil stock......with out the additives
"Additional MTM oil traction measurements were
performed on various engine oil formulations to evaluate
if realistic engine oil formulations can lead to extremely
low oil traction. Figure 7 shows the oil traction of various
engine oil base stocks as categorized by API6. These
oils do not contain any additives. Note that Group III and
Group IV base oils exhibit substantially reduced oil
traction. The lower traction coefficient of the VHVI and
synthetic base-stocks is directly related to their lower
pressure-viscosity coefficient7.
Figure 7 Traction coefficient of various base oils
While Group I and Group II base oils are prevailing in
today’s commercial market, Group III and Group IV base
oils are gaining popularity as the basis for high
performance, more expensive, engine oils. These high
performance oils may inadvertently cause cam problems
due to their very low traction coefficients. The rankings
of Group III and Group IV reversed when all base oils are
formulated with the same additive package as used in
the HDEO (Figure 8). However, both are still very low, at
a level similar to LTO.
Conclusion
1. The high-pressure rheological properties of VHVI
and synthetic base-stocks have to be carefully
optimized in a fully formulated lubricant in order to
minimize wear as demonstrated in the N14 engine
cam wear test."
so buy a good quality oil and you will be OK
Conclusion
cam wear test."
#57
Since you repeat Brad Penn like a holy mantra in every oil thread, I'd ask. Where can I buy one ?
Unless I have easy access to Brad Penn/Kendall, I'll most likely go with VR1 following this thread.
#58
Charlie, I've never seen Brad Penn oil or heard of it either.
Edit: http://www.bradpennracing.com/default.asp
#60
I started a thread on zddp a while back and found it quite interesting. My conclusion was to run Valvoline VR-1 20-50..............for now.....
http://forums.corvetteforum.com/show...highlight=zddp
