Intake Manifold not Sealing?
Old 03-04-2007, 11:12 AM
Mikef714
Mikef714's Avatar
Default Intake Manifold not Sealing?
Hello Everyone – I recently replaced the intake manifold gaskets on my 1972 LT-1. Everything was fine for the first few hundred miles but now I notice some coolant pooling around the second bolt in from the passenger side front (next to the heater hose connection. The bolts are torqued to the proper spec. Any ideas what I might be causing this and/or how to fix (maybe replace the intake gaskets again but I am not sure what I may have done wrong the last time)? Any thoughts are appreciated - Thanks
Old 03-04-2007, 11:25 AM
blctalon
blctalon's Avatar
Are you sure it's not the heater hose adapter leaking where it threads to the manifold or the hose connection itself?
80TexasC3
"Rodstoration &am p;quot; In Progres
Support Corvetteforum!
80TexasC3's Avatar
Did you put some RTV around the threads before inserting the manifold bolts? Is recommended and really helps.
Old 03-04-2007, 12:01 PM
Glassbowtie77
Glassbowtie77's Avatar
I also like to put a bead of sealer around the water jackets on both the heads and intake as well before installing the gaskets and torquing everything down. Also what did you torque your manifold bolts to and did you follow the correct torquing sequence?
Old 03-04-2007, 01:15 PM
Mikef714
Mikef714's Avatar
Thanks for the suggestions. I will check the heater hose. I did use a small amount of silicone around the water jackets and used the specified torque value and sequence contained in the repair manual I have.
Old 03-04-2007, 01:49 PM
GaryS
GaryS's Avatar
Don't forget to put sealant on the threads of that bolt! It is not just torque.
69monzaredbigblock
69monzaredbigblock's Avatar
I believe some of the intake bolts go into the coolant passage way. You need to seal the threads on the offending bolts.
Old 03-04-2007, 06:02 PM
AlCherry
AlCherry's Avatar
Remember, when you use a sealant of any type, make sure to clean any excess, as to not get any in the oil passages. Pro's know this. Save your motor.
To Intake Manifold not Sealing?
Quick Reply: Intake Manifold not Sealing?
