Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-09-2007, 12:21 PM   #1
dktorre
Junior Member
Support Corvetteforum!
Default Reflectix Installation
When you install the reflectix on the floorboards and the center console is it helpful to do as much as possible behind the door panels also? Has anyone tried this?
dktorre is offline   Reply With Quote
Old 02-09-2007, 01:16 PM   #2
SanDiegoPaul
CF Senior Member
SanDiegoPaul's Avatar
Location: San Diego - Deep Within The State of CONFUSION!
Quote:
Behind door panels? I think that would just make them ill-fitting and loose. There is enough on the roll though, if you wish to do so. I had a couple feet left over on my roll and I even padded over the diff. and under the rear deck...
Diff:
Click the image to open in full size.
Driver Side Reflectix:
Floor Treatment before Reflectix: (Rustoleum)
I also put a coating of Por15 on the floor. I may never have rust again!
SanDiegoPaul is offline   Reply With Quote
Old 02-09-2007, 03:05 PM   #3
68 NJConv 454
CF Senior Member
68 NJConv 454's Avatar
Send a message via AIM to 68 NJConv 454
How does the reflectix perform? Does it block any sound at all? How did you mount it? does it have a sticky side or did you spray glue?
I'm thinking about mounting that around my firewall since I'm running sidepipes so the floorpan should get too hot.
In my case it would be beneficial to install the reflectix in the doors to protect from sidpipe heat, but thats why I sprayed lizardskin heat/sound insulation inside the doors. I'm sure it would be a major PIA to fit that reflectix stuff inside the doors. Just sticking it to the door panel would affect fitting.
68 NJConv 454 is offline   Reply With Quote
Old 02-09-2007, 03:42 PM   #4
dktorre
Junior Member
I have not driven the car since installing the reflectix so I can't tell you how it performs. There are a number of posts that swear by it however. It is all a matter of how much you are willing to spend. Reflectix is cheap in comparison to other products. It is not sticky, so you must use a small amount of adhesive to hold it in place, and metal faced tape to tape the seams. The adhesive I used was a 3M product and worked great.
Old 02-09-2007, 04:38 PM   #5
SanDiegoPaul
CF Senior Member
The stuff works great. My car had just had the A/C system completely rebuilt from ground up - yet even though it blew cold, after a half hour or so the cabin was soooo dang hot the A/C couldn't keep up. It was wierd - you could feel cold air from the vents but the cabin was so hot you wanted to roll down the windows.
Reflectix fixed that. No way did it help noise level though unfortunately.
Old 02-09-2007, 05:54 PM   #6
MEGALADON
CF Senior Member
MEGALADON's Avatar
Location: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
REFLEXIT is in no way a sound deadener.
MEGALADON is offline   Reply With Quote
Old 02-09-2007, 06:13 PM   #7
68 NJConv 454
CF Senior Member
Just wasn't sure if it was backed with an asphalt based or foam surface that would help insulate the sound.
I don't need it, have my interior and underbody sprayed with a ceramic heat / sound insulation, just curious as to the qualities of reflectix.
Old 02-09-2007, 06:58 PM   #8
ddale1977
CF Senior Member
ddale1977's Avatar
Haven't used Reflexix but did my entire interior with FatMat-Rattle Trap...70 mils thick and doubled up where I could. Rattletrap is the thicker version of the Fatmat brand. Made a hugh difference in sound deadening. I highly recommend it.
Does smell a little when closed up for a while. Hoping that goes away in time.
ddale1977 is offline   Reply With Quote
Old 02-09-2007, 07:27 PM   #9
MEGALADON
CF Senior Member
MEGALADON's Avatar
Quote:
DYNAMAT change something in the material they used in the tar stuff they use. Dynamat does not give off a tar base smell anymore. They used to be real bad about that.
Old 02-11-2007, 06:22 PM   #10
68 NJConv 454
CF Senior Member
whats a ruff estimate of what you spent on the dynamat extreme for the whole interior? Did it work well with the heat and your undercar exhaust?
Old 02-11-2007, 08:13 PM   #11
ddale1977
CF Senior Member
ddale1977's Avatar
You ask about Dynamat...don't know but here's what I know about Rattletrap...a similar product.
I got a 100 SF roll of Rattletrap. Rattletrap is the thicker version of the FatMat brand. It's supposed to be 80 mils think. The regular Fatmat is about half as thick. Here's the web site. $139 plus shipping.
http://www.fatmat.com/Rattle%20Trap/...bulk%20pak.htm
I think Dynamat is about the same thickness.
I totally stripped the interior. Might as well do it...cause you wont want to go through it twice. Double up where you can.
Made a tremendous difference in 'noise' suppression. Same with insulating. Mine has a little smell right now when closed up. I think it will go away.
Sending you this as a comparision.
Doug
Old 02-12-2007, 02:11 AM   #12
sperkins
CF Senior Member
sperkins's Avatar
Scott Perkins
Quote:
I love it that way. I want to hear all those dollars I've got in the engine.
sperkins is offline   Reply With Quote
Old 02-13-2007, 10:45 PM   #13
ddale1977
CF Senior Member
ddale1977's Avatar
Yeah...I like the engine sound. I just don't like the road noise from tires and wind noise. To each his own...
Old 02-14-2007, 12:40 AM   #14
7T1vette
CF Senior Member
7T1vette's Avatar
The heat was a much bigger problem than the road noise. Reflectix did the trick for the heat. And, IMO, it did help a bit with the road noise.
7T1vette is offline   Reply With Quote
Reload this Page Reflectix Installation
Tags
car, installation, reflectix
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Interior still hot!!! 71SoCal C3 General 90 11-25-2005 09:56 AM
c3 carpet Skruball73 C3 Tech/Performance 11 01-21-2005 11:28 AM
Lots of work. I hope it pays off. jmzvet C5 General 21 01-01-2005 06:58 PM
Dynamat vs. Frost King RocketDawg C5 General 107 11-27-2004 10:29 PM
Installed the Elite Engineering Abs-of-Steel Patches C5 General 37 09-24-2004 12:14 AM
Should I use adhesive for carpet installation? Tele_Man C3 Tech/Performance 17 07-06-2004 03:49 PM
C5 Mods from Lowes Snafu C5 Tech 15 08-26-2002 11:06 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
