Need Help: Which flex plate for this engine?
This is all the information I have on this engine. I have no idea what flexplate to match with this and the one I have won't work. I tried to call the guy I bought it from with no luck. I might be able to find the machine shop, but that's hit or miss. I'm guessing internally balanced, but I don't want to be wrong.
Random facts:
4 bolt main
-Comp Ratio 10.1
- hp and torque peak @ 5400 rpm
-The hp and Tq numbers are exact, engine was dynoed by AR racing when it was built with 437hp & 468 Ft. Lbs torque, This was with 4bbl carb, shuld be ALOT MORE if you went with a TPI system.
Machine Work
-Select high tin block 4 bolt main. 030 over
-Align bore check run out. Full race clearancies
-Mag check-Press check
-Hot Tank
-Bore Torque Plate Honed
-Clearence Block
-Shot Peen Rods
-Dynamic Balance Assembly
-File Fit Rings-Blue Print Clearence
-Press pistions to Rods
-Install Cam Bearings- freeze plugs
-Port Blue Print Cyllinder heads
-Final Assemble Full Rotationsand Top end
HEADS
-Kenny Duttweiler Trick Flo bowls blended Full
-2.02 / 1.60 valves
-1.25 springs 7 degree super locks
-Porting 3/8 Stud Guides
-Mild Port work
-Hi Performance roller rocker 1.6 ratio
-Comp Cam Polished+Matching Rpm Intake
-112 degree center line 487-490 Lift Corrected 1.6 ratio= 520 / 532 Lift
-226/228 dur. @0502
-2,000 Stall
PARTS
-Keith Black Hypervtecic S.I. Pistons 9.8 Tol
-Eagle Steel Crank Sized + Indexed
-Childs + Albert - 22 gapdura Moly File Fit Rngs
-Durabond Cam Bearings
-GM Pink Forged Steel Rods
-ARP- wavelock- rod bolts
-Clevite Rod + Main Bearings Tri- Metal 77
-Comp Cam Lifeters
-Colys True Roller set
-Comp Cam Locks
-Comp cam Xe Chrome Moly Push Rods
-Dyna Gear race oil pump
-ARP steel drive
-ARP head bolts
Fel Pro Gaskets
Random facts:
4 bolt main
-Comp Ratio 10.1
Machine Work
-Hot Tank
-Clearence Block
-Shot Peen Rods
HEADS
-2.02 / 1.60 valves
-Mild Port work
-226/228 dur. @0502
-2,000 Stall
PARTS
-Comp Cam Lifeters
-Comp Cam Locks
-ARP steel drive
-ARP head bolts
Fel Pro Gaskets
Except for the heads the description is almost identical to my 383 stroker engine purchased from A.R. Racing - Performance.
I just contacted Mark at A.R Racing the other day regarding flexplate id. Some punk grabbed the one sent with the engine out of my garage. It has been a couple of years since I've bought the engine and I wanted to make sure I buy the correct one before I start the install next month. He emailed right back and told me what type to buy (400 SBC - 168 tooth external balance).
Mark's email is: arracingunl@***.net <arracingunl@***.net>. He is very good about answering questions. You might want to ask him since he is the engine builder.
On second look, I just noticed you are in VA. A.R. Racing is located at 14333 Snakecastle Road, Summerduck, VA. I don't know how close that is to Norfolk, but at least your in the same State.
Binney77-
I don't know if the flexplate offer was to me or cduemig. I've got another one comming from Summit, so hopefully cduemig can take you up on your very generous offer.
more questions
You neglegted to state what size engine this is, is it a 350, has it been stroked to a 383, is it a 400, has it been internally balanced. Why doesnt the flexplate fit, is the center hole too small, this would indicate a 1 piece rear main flexplate that you are trying to put on a 2 piece block. Happy to help, just need a little more info.
I wrote the guy from AR, we'll see what he has to say. If I can use the flexplate from the ZZR I'd really appreciate it. I'm to the point where I can put the engine back in, but this and the valve covers are holding me up. The valve covers are cosmetic and can be fixed later, this can't. I'll let you know.
