rpm difference ,between rear gears,373 and 411
Old 01-03-2007, 05:08 PM
Billysvette
Billysvette's Avatar
Default rpm difference ,between rear gears,373 and 411
Does anybody know what the rpm difference is between a 373 and a 411 gear? with a sbc.I guess i should also say ,at cruiseing speed.or 4th gear ,1 to 1.
Old 01-03-2007, 05:20 PM
69 N.O.X. RATT
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Go to Richmondgear.com and play with the performance calculators, it will give you exact numbers
Old 01-03-2007, 05:30 PM
carl a
carl a's Avatar
in 3rd gear in my turbo 400 (1 to 1 ) with 373 rear gears i was singing along at 3500 rpm's at 60,i would guess that with 411's you would be from 3800 near 4000 rpms at 60 mph..this is why i installed a 4 speed o d trans,,,dropped to 2200 rpm's at 80 mph.i had dodge neons flying past me with the th 400...thats at 60 what happens when you wanna go to 80? i have had this car now up to 145 and it isnt even winding outi would think of installing a 5 speed with the 411 or 373 rear gears cuz your not gonna like it on the highway. plus gas milage will go up.i went from 8 mpg to 17 with the 700r-4 swap
Old 01-03-2007, 05:34 PM
Gordonm
Gordonm's Avatar
10% difference.
Old 01-03-2007, 05:47 PM
wfo76
wfo76's Avatar
What do you have now?
Neither of these ratios is a highway cruise gear without an overdrive tranny.
Old 01-03-2007, 07:42 PM
mandm1200
Support Corvetteforum!
mandm1200's Avatar
Originally Posted by Gordonm
10% difference.
To find out the new rpm at a specific speed:
411 / 373 x rpm (old) = rpm (new)
The change will yeild about 10% higher rpms at a given speed.
Old 01-03-2007, 07:47 PM
GTR1999
GTR1999's Avatar
Received 2,597 Likes on 1,330 Posts
Our 373 with 1:1 run about 3400@ 65 mph w 225x70-15's I guessing 411 would be about 3800-3900 RPM @ 65mph
I like my 336 automatic much better- must be getting old! about 2900 @65 mph
Old 01-04-2007, 09:35 AM
mrvette
mrvette's Avatar
Correct, which is why when moved to Florida here in '97, the speeds and length of any drive were much higher and longer than anywere near DC region....so in went the overdrive.....at first it was a 700, but I took it out, and put in a 200 4r.....which with 336 feels much better....
Old 01-04-2007, 03:27 PM
Billysvette
Thank you ,
To rpm difference ,between rear gears,373 and 411
Quick Reply: rpm difference ,between rear gears,373 and 411
