Transmission Indicator
I have a 76 vette. It is an automatic.
My question is.........isn't there supposed to be some type of indicator on the console that shows what gear I'm in. It appears to me that it would have a red indicator pointing to the drive I'm in.
I guess mine is missing. Where can I get one and how hard is it to put in.
Thanks in advance,
Mike
Thanks in advance,
Mike
I don't know about the 76, but my 73 doesn't have one either and there's not even any opening behind the lens that an indicator could slide through. they added one at some point, I just don't know when
Was this an odd option? I remember my neighbor, used to have a '76, and I clearly remember it having a shift indicator. Obviously a manual doesn't have one...but auto cars should have.
I've had my console apart and the only opening in the metal back piece is for the light bulb... no way for anything connected to the shifter to get behind the lens. Am I just missing something here?
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
I'm not trying to be a wise *** here, but does anyone really think that a car manufacturer would produce a car without a tranmission indicator as to what gear the car is in? Just think of the law suits if someone put it into reverse when thinking it was in drive and ran over a crowd of people.
EDIT-OK checked this 73 and there is no way a pointer could follow under each letter or number to indicate the exact gear you are in.There is a bulb that lights the complete dial or lens but nothing to indicate the gear.
Regardless of what anyone's intuition is ... It's a fact that GM did design & build C3 auto with NO gear indicator.
I think (please correct me if you have verifiable info) that an indicator first appeared in 1977MY.
http://www.zip-products.com/Zip/prod...AEC6DC40833124
75 does not have a pointer i own a 75 and it never had one. The only thing is the 3 raised areas on the left of the shifter that correspond with 3 2 l this is the original shifter plate in my car the only thing i did was rebuild it and paint it.
Well, I know the '75 and '76 had the indicator. And according to Zip, the '69 had one.
