Hydraulic Cam break-in procedure
I know you should as a rule of thumb start the car and immediatly rev the engine over 2000 rpms and vary it a little from 2000-3000 for 20 minutes....
Could I actually drive it on the freeway for this break-in time keeping it within this RPM range? Reason why i ask is that my neighbors are just going love me for running my chambered sidepipe exhaust at those RPM's for 20 minutes
jim
jim
I don't know your situation, but I can't see how you could start it up and get to the freeway while not letting it dip below 2000 rpm at all. then when you are on the freeway, in order to drive while transitioning the rpm to get proper splash to get a good break in, I think you would be pulled over by the cops looking like you were on some serious drugs - slow down - speed up - slow down - speed up slow down - you get the picture. Why take the chance. do it once and do it properly where the car sits. Just my opinion.
Good luck,
Greg
Good luck,
Greg
You really should do it in the driveway so you can keep an eye on it. Why don't you go talk to the neighbours first? I've found most people are pretty reasonable if they know *why* there's all this noise and they know it will only be for 20 minutes.
Start that puppy up at 3:am if your going to make the neighbors
mad do it the right way. Start it up in the garage make sure you have
good oil pressure no leaks, put the garage door down about three quarters
of the way, you can add fans if you like to help blow out some exhaust fumes,
you don't have to be in the garage all the time its running, with it in the garage
and the door down most of the way the garage will knock off a lot of the sound
waves,
waves,
I thought I would have a problem when I broke my cam in, I also have the chambered exhaust. I live in an apartment and talked to the neighbor who would be affected the most. He didn't really care. Sometimes there is someone much further away that will complain. If you own your home, do it at a reasonable time, and let the next door neighbors know, I don't think you'll have much of a problem.
I also thought of trying to pick up a couple of 'junk' mufflers from a muffler shop and temporarily hooking them up to the tailpipes with the flexible style of pipe.
At 2000 rpms the noise is bearable; it's when you start getting closer to 3000 rpms that noise becomes as issuse.
Location: Las Vegas - Just stop perpetuating myths please.
Don't forget the GM EOS oil additive. Can't recall the full name or part # but do a search. Cam break-in is crititcal to cam life and modern oils are missing what used to help a cam live.
Good luck.
cardo0
Good luck.
cardo0
Agree - with run in place and check for leaks or stuff out of place....when I fired my open header BB two weeks ago the next door neighbor came over because he thought my house was on fire from all the oil and stuff burning off with car running in the garage....didn't say much about the noise.......
Use the GM additive. about 12.00 for a small bottle..anything to give the cam half a chance to survive...thinner oils help too. I used Rotella because of the added zinc content - reommended by COMP Cams.
Maybe this is a dumb question, but... Is this a hydraulic roller cam? Reason I ask is that I've heard that you really don't need the full-on "20min at 2000RPM" break-in for a hydraulic roller cam.
What say you all?
What say you all?
What say you all?
What say you all?
