Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-17-2006, 01:14 PM   #1
1Z87L8
CF Senior Member
1Z87L8's Avatar
Default Carburetor bolt torque
can someone tell me what the torque is for
the 4 main bolts on the Q-jet to manifold?
my AIM shows where its supposed to be but
the numbers and whether its inch or foot lbs
is completely faded
1Z87L8 is offline   Reply With Quote
Old 11-17-2006, 01:27 PM   #2
Jughead
Senior Member since 1492
St. Jude Donor '09
Support Corvetteforum!
Jughead's Avatar
Location: 1.Just because I'm paranoid doesn't mean people aren't out to get me... 2.That which does not kill me will probably hurt like hell. 3. Islam is the enemy.
Send a message via AIM to Jughead
Holley specs are 100-115 INCH LBS.
__________________
1970 454- M-22 W/Hurst Comp+ 4 speed, Sidepipes, Mellings, Clevite 77, GMPP Al heads, Manley, Moroso, NO cup holders &
Not Correctly Restored Stingray................
When "Cool" was Measured in Cubic Inches!~Nuthin' Like the Sound of a Solid Lifter BB.
Jughead is offline   Reply With Quote
Old 11-17-2006, 01:46 PM   #3
sweethence
CF Senior Member
sweethence's Avatar
Location: Rochester NY, Drive it like you stole it, 68 327 4 speed coupe
Send a message via MSN to sweethence Send a message via Yahoo to sweethence Send a message via Skype™ to sweethence
Quote:
yes inch pounds for sure
sweethence is offline   Reply With Quote
Old 11-17-2006, 03:18 PM   #4
Glassbowtie77
CF Senior Member
Glassbowtie77's Avatar
I just did this recently and if I remember correctly on a Q-Jet it is 140 inch lbs. Make sure you snug each bolt down evenly before torquing them.
__________________
'77 L48 Coupe
Edelbrock Performer 2101, Hooker Super Comp Ceramic Coated Sidepipe Headers w/ 4" Sidepipes and Hooker Max Flow mufflers, Proform Hei Distributor, Stewart Stage 2 Water Pump, Accel Coil & Accel 8mm Superstock Wires, 100 amp Alternator, Cloyes Street True Roller Timing Chain, VB&P 550lb springs, VB&P 360lb Monospring, VB&P Smart Struts, VB&P 3/4" Rear Sway Bar, Bilstein Sport Shocks, Firestone Firehawk Indy 500's 255/60-15's, TH350, 355 rear.
Glassbowtie77 is offline   Reply With Quote
Old 11-17-2006, 10:08 PM   #5
a1sensei
CF Senior Member
a1sensei's Avatar
I don't usually pull out the torque wrench for this one but supervette77 is right that you need to snug them evenly. I usually use a nut driver (screwdriver handle on a socket). That's fairly safe. You can crack a quadrajet's body pretty easily with a socket wrench (ask me about the bead of JB Weld running down the front of the one on my big block.) God bless, Sensei
a1sensei is offline   Reply With Quote
Old 11-18-2006, 01:45 AM   #6
Victor
CF Senior Member
Victor's Avatar
stupid question:
are there 12 inch pounds in 1 foot pound?
Victor is offline   Reply With Quote
Old 11-18-2006, 02:13 AM   #7
Bob Onit
CF Senior Member
Bob Onit's Avatar
Quote:
Originally Posted by Victor
stupid question:
Yes Sir
Bob Onit is offline   Reply With Quote
Reload this Page Carburetor bolt torque
Tags
bolt, carb, carburator, carburetor, corvette, jet, lbs, mounting, qjet, quadrajet, spces, spec, torck, torque, torue
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Any chance of my '82 rear end not exploding.. SuprJames C3 Tech/Performance 152 07-03-2005 04:52 PM
GM announcement on LS7 & other engine stuff Troy Roberts C6 Z06 Discussion 131 09-11-2004 11:23 PM
Lack of HP in the C6 Roadfrog C6 Tech/Performance 62 01-23-2004 07:22 PM
GM's Nov 28 Gen IV Announcement Curtis A. Franz C6 Corvette General Discussion 37 11-04-2003 06:10 PM
Horsepower and Torque Estimates? bence13_33 C3 Tech/Performance 23 10-05-2001 12:05 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
