Innova #5568 timing light How to use
Old 11-15-2006, 11:47 PM
carnut114
carnut114's Avatar
Default Innova #5568 timing light How to use
Hello, I just bought a innova 5568 and i am not really sure how the timing works on it. The manual is a bit confusing. I have only used my old cheap timing light before this. I am trying to time my 350 camaro to get a feel for this light. Then i will do the dwell and timing on the corvette. Thanks Eric
Old 11-16-2006, 06:20 AM
Fevre
Fevre's Avatar
If it is anything like a dial back timing light you adjust the light to what ever deg adv you want and then adj the dist until the balancer reads 0.
Old 11-16-2006, 01:38 PM
carnut114
carnut114's Avatar
Hello, This EQUUS/INNOVA 5568 pro timing light i believe is a dial back timing light. Thankyou for your input i will try it.
Thanks Eric
Old 11-16-2006, 01:44 PM
pws69
pws69's Avatar
Thanks Eric
It is that and a lot more - Dialback Timing / Dwell / Tach / Voltmeter
The trick is getting familiar with the various little ICONS on the screen. It can be confusing! You need to 1) understand the manual 2) PLAY with it - press the various buttons and watch the icons change. Once you get used to the user interface, you will love it!
I have had mine for a couple of years and I find that, because I don't use it often, I have to review things for a bit before I get down to business.
Old 07-25-2010, 05:51 PM
Patrick73
Patrick73's Avatar
I dropped and broke my 30 year old timing light. Bought a Innova 5568 and the instruction manual is not that great. Frustrating. Still playing with it all day trying to figure it out.
Old 07-27-2010, 01:00 PM
c3_dk
c3_dk's Avatar
And it doesn't work with my MSD 8572 + 6AL box :-((
Old 07-27-2010, 01:33 PM
pws69
pws69's Avatar
That's interesting - although I have never tried, I was of the impression that it was supposed to work with "electronic ignition" setups.
What behavior have you seen using it with the 6AL?
Old 07-27-2010, 03:55 PM
jordan89
jordan89's Avatar
I have this timing gun and have been wanting to check and adjust the timing on my Camaro, but haven't gotten to do so. It's still brand new. I need to get to doing this ASAP to try it out.
To Innova #5568 timing light How to use
Quick Reply: Innova #5568 timing light How to use
