Will a ramjet 350 fit?
Go out and measure from the top of the front of the block to the hood in it's closed position. If it's 9.75" or higher, then you have enough room. If it's under 9.75" then it won't fit under your hood.
I've got some pictures under my photos...
off to the left here.
It' s under an L88 hood but I can take some other pictures to check how far above the fenders the top sits....if someone wants that.
Sorry for the late response...I don't regularly check the forum. The oil pan on the Ramjet needs to be repaced with one that has the room for the steering links. The stock RamJet oil pan is sloped and will hit the links. When you do change the pan, a few of the main cap bolts will need to be changed because of the windage tray bolted to the main caps (different bolts).
Great explanation. Thanks for the info.
#33
I just used a later model chevy pan...
The problem I had with my RAmJet oil pan was that it hung way too low. The steering interference was minor in my case but was going to need to be addressed.
As far as the windage tray, I was just going to cut the edges off until a friend of mine suggested I bend the edges down to avoid disassembling the bottom end.....so that's what I did, and the regular old late-model Chevy pan bolted right on.
#36
Modifying the oil pan won't have an effect on the overall height of the engine.
I too would like some input on whether or not the Ram Jet will fit under the stock hood. Im ordering my engine next week
#37
Here's some cowl / height pics...
#39
A view from a little further back....
