tightening head bolts...
every how long head bolts should be tighten? i have alu heads on a 406ci application, the engine builder recommended me to re-torque bolts after a few hundred miles after running in but i never did....
Senior Member since 1492
I don't remember the source, one of the rebuild books though. I checked the torque again after a few hot/cold cycles. Maybe 100 miles. None of the bolts needed re-tightened.
Doesn't the head gasket decide if it needs retorquing or not?? On my head gasket it said to retorque after one heat cycle.
I never did because it requires the headers to be removed to get at some of the bolts plus I would have to pull the valve train.
Before pulling the heads this fall I did test some of the bolts with my torque wrench and one proved to be loose.
AFR 210's torque
HEAD BOLT TORQUE:
All Aluminum heads should be torqued to 65-70 ft/lbs. This should
be done in the proper General Motors sequence in 10 ft/lbs increments beginning at 40 ft/lbs. Moly lube should be applied between fasteners, washers and areas around head bolt to prevent galling and improper torque values. All high compression, supercharged, turbocharged & nitrous motors should receive a retorque after the first run-in and complete cool down.
________________________________________ _____
Panic,
Above are the instalation instructions
I found it in the FAQ on the website
Heres a link to the site so you can read it all.
http://www.airflowresearch.com/sbc.php
Panic,
Originally Posted by Bob Onit
HEAD BOLT TORQUE:
Panic,
Panic,
the retorque after the first run in has been done at builder's place alright, i wanted to know if a second re-torque should be needed, after a few hundreds miles on the street...thanks/Giu
Panic: If I were you I wouldn't touch it. At the most it would require one re-torque. I don't see it needing a second one. Many head gaskets (the "composition" type) do not need a re-torque at all. Shim gaskets need one re-torque.
Originally Posted by panic
t
"All high compression, supercharged, turbocharged & nitrous motors should receive a retorque after the first run-in and complete cool down"
Since you have had the heads re-tourqued once I would say...Dont worry one bit
Your all good to go!
