Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-15-2006, 11:19 PM   #1
supervette2
CF Senior Member
supervette2's Avatar
Default Help with master cylinders
Does anyone know if these will work with the corvette power brake setup.
Please help. http://www.wilwood.com/Products/006-...VAMC/index.asp
supervette2 is offline   Reply With Quote
Old 10-16-2006, 10:51 AM   #2
Duke94
CF Senior Member
Duke94's Avatar
I would say not. On a PB setup, the pushrod is part of the booster and the one you showed has it attached to the M/C itself.
Duke94 is offline   Reply With Quote
Old 10-16-2006, 01:05 PM   #3
0Corvette Engineering
CF Senior Member
Corvette Engineering's Avatar
Not without a lot of fabrication!
That is a single master clyinder ment to be used in pairs, one for the front and one for the rear with a balance bar between them.
Wilwood does make a NICE aluminum MC;
http://www.wilwood.com/Products/006-...TCMC/index.asp
You'd want PN 260-8556 for power brakes, and it will still require a little fab of the pushrod I think
Corvette Engineering is offline   Reply With Quote
Old 10-16-2006, 02:06 PM   #4
lvrpool32
CF Senior Member
lvrpool32's Avatar
Send a message via AIM to lvrpool32
I have the polished one in my car, along with Kieth's wilwood brake kit (front and rear) and it works flawlessly.
Nick
__________________
lvrpool32 is offline   Reply With Quote
Old 10-16-2006, 03:12 PM   #5
70 LS1
CF Senior Member
70 LS1's Avatar
Those are really nice. I need the 7/8" one, but just don't like the $200 price tag.
__________________
Jeff
1970 convertible
Powered by LS1 and six speed
Z06 brakes
70 LS1 is offline   Reply With Quote
Old 10-16-2006, 09:43 PM   #6
supervette2
CF Senior Member
well to my demise I have been shot down again in yet another attempt to try to fit this procharger filter on. The point was to find enough room with that master cylinder because it is 3 inches shorter than the stock one so I can fit a intake pipe in there.
hmmmmm. I did get off the phone with a brake shop today. They were saying i could relocate my booster and master cylinder. Not an easy task in my mind. I have had this procharged motor sitting in my car with no intake hose and no exhaust system but the headers. Im so close I can taste it. But the clearances suck so bad by the brake system.
Either relocate brakes and custom hood OR
Modify supercharger bracket and make a power steering pump resevoir.
A note on this method. My supercharger pulley is so tight already putting an idler arm on the bracket would be a bad idea unless it gave me more slack.
Is there a path of least resistance. I think not.
Im open to suggestions at this point.
Old 10-16-2006, 10:23 PM   #7
70 LS1
CF Senior Member
70 LS1's Avatar
How about manual brakes. That should free up some room.
Old 10-17-2006, 07:41 AM   #8
CF Senior Member
I have manual brakes, properly designed they work pretty dang good.
just make sure to get good pads, i.e. NOT lifetime!
Old 10-17-2006, 09:15 AM   #9
Duke94
CF Senior Member
Duke94's Avatar
Quote:
I agree, I have manual brakes on my 71' and they work fine. A little more effort but very acceptable.
Reload this Page Help with master cylinders
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pls help with clutch issue ASAP 94 M-6 C4 Tech/Performance 11 02-11-2004 07:55 AM
Help with clutch slave cylinder Hershey C5 Tech 10 01-25-2004 12:48 PM
Help! Need master trobleshooter help with '93 LT-1: Dies when given gas! goatcrazy C4 Tech/Performance 40 10-23-2003 09:57 PM
HYDRATECH GROUP PURCHASE Paul in Warren C3 Tech/Performance 121 04-17-2003 11:49 AM
Clutch/Slave master cylinders....PLEASE HELP STUCK ON THE SIDE OF THE ROAD. apollo30346 C4 Tech/Performance 10 11-30-2001 03:14 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
