Does Edelbrock make a good carb?
I have a Speed demon 750 vac secondaries with electric choke if you are interested. like new. ran great. original packaging, manual, video, etc.
$250 shipped.
ccherri@yahoo.com
ps...I ran one of the "edlebrock" carbs and they are crap. dont't bother.
$250 shipped.
ccherri@yahoo.com
edelbrock has a good out of the box carb. But as far as performance goes the Q-jet is a better carb. There's a reason they made & used these carbs for so many years.
The q-jet does require a little tlc. And matybe a little tinkering from time to time. A rebuild kit for a q-jet is cheaper than a new/used edelbrock or holley, and this my friend translates into money I can spend elsewhere.
Doug Roe wrote a book on Rochester carbs and it is without a doubt the most useful piece of literature I have ever bought. He focuses heavily on the Q-jet. I was gonna buy a holley, saw the price tag, bought his book instead and after a couple rebuilds I couldn't be happier with my Q-jet
They all have their problems
Hollies had a problem with power valves and back fires taking them out, Quadrajets have fuel well leaks, I've seen complaints about some the Holley clones as well. To say the current rendition of the Edelbrock is a dyed in the wool carter afb is somewhat of a misnomer, as there have been quite a few changes to the carburetor. They all have their pluses and minuses. I would say for a street car with a mild setup there is not a darn thing wrong with a Edelbrock. The have become extremely reliable. I prefer that to tear downs anyday. However if you are after all out screaming performance maybe the holley or a reworked Quadrajet is more to your likeing. You can also get dual four Edelbrocks which will probably do allright as well. If weber took over edelbrock manufacture it does not mean that the quality has necesarily gone down. Weber has made some fine fuel sytems for a long time. It is all about application and particular problems with each brand. You will not hear me condem any brand just because of a particular problem. And you will not hear me praise any of them for being the only one to use.
I like my Edelbrock 1406. Easy to tune, predictable, and reliable. If I'm giving up a little HP that's fine with me.
Here's a Car Craft article on the AFB.
http://www.carcraft.com/techarticles/carb_tuning/
I bought a 600 CFM Performer for my vette and have been mildly frustrated. I was recently given a Holley 1460 rated at 750 CFM which I installed and ran. I will be buying the correct size Holley at the first opportunity (read: when my wife lets me).
The Holley transitions much better, at least for my mild motor.
Originally Posted by bondoboy
Your vacuum leak is probably a worn throttle shaft bushing.
Opened a can of worms here didnt ya! I told you everybodys got their brand. Seriously...if you're running an average street motor, then an Edelbrock is a good and very simple carb. Holleys being easier to work on is just
Mine runs great, but I would rather have a quadrajet. Mine was already changed when I got the car. I have to agree with the majority, given the choice, go with the quadrajet.. The Eldebrock is a however a good "get you by"..
Originally Posted by 81corvettevortec
A friend of mine has a 650 edelbrock performer carb that he will sell for about $100. I am not sure how good of a carb it really is. i was wanting a holley 650 double pumper, but this might work in the mean time. my engine is a 355 with vortec heads, KB rotating assembly with about 10:1 compression, Comp cam 268 grind, and a performer vortec intake. thanks for any help or suggestions,
Ryan.
Ryan.
Yes they do. And they are very dependable. My Holley was just a source of misery. The Edelbrock #1406 has served me well with no issues for three driving seasons.
#33
Why is a holley harder to work on....
I prefer a Quadrajet but Holleys get my vote for ease of maintenance and adjustment
#34
Everyone has their own ideas on carburetors. I myself am not a carb guy, but I can rebuild an Edelbrock with no problem. I like them for their simplicity. Also, I don't think Edelbrock made a 650. It's probably a 600cfm. Summit sell's a Carter thats a 650.
#35
You're right, its because of the thunder series. I havent delt with them personaly. I can only find the Carter AFB's in my old catologs, so I guess you would have to shop EBAY.
#36
