speed demon 650 carb ?
i was wondering if this carb is big enough for my 383 stroker w/ trickflow heads and a 231/231 duration cam.........if it is, where should i start with jet sizes?
A better choice would be a 750, the 650 will most likely, depending on manifold choice be your limiting factor.
Cam is also pretty mild for a 383.
What are you expecting for HP 390 (300 RWHP) ?
i have 1.6 roller rockers...i also have a 750 holley dp laying around...i am expecting around 400 hp. would i be better off going w/ the 750? i know that the jet sizes are about the same sizes on both of them. any advice would be appreciated.
Well lets start off saying it takes about 425-450 SCFM to make 400 HP. That's unencumbered flywheel HP (gross) not SAE (net) or RWHP.
That said, most builders will recomend using between 2/3 (429 SCFM) and 3/4 (487 SCFM) of a carburetors rated flow to calculate which carb to use.
OK that means that a 650 would be on the low to medium side for 400HP, but that would be it, the limit to your engine.
Tell us a little more about your heads, and cam.
750 minimum. No vacuum secondaries, use the dp. Holley's website has a section that lists all their carbs with the baseline settings. Set the carb to that and tune/adjust from there.
$250 + shipping.
ccherri@yahoo.com
Received 4,574 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I've got a 650 double pump Speed Demon on my 383 in my 61. It feels a little under carbeurated. If I had it to do over I would go with a 750.
